[MPICH] Unable to execute process on different machines (ERROR : bash: line 1: orted: command not found)
Pravin_Kumar at jubilantbiosys.com
Thu Dec 21 05:43:12 CST 2006
Hello Sir
I am trying to execute the process on two machines for which i am using
mpiexec here when i give the machine name to execute the process using
option -machinefile or -hostfile or just using -h <machine name> i get
following the error :
[server:02392] ERROR: A daemon on node samiron failed to start as expected.
[server:02392] ERROR: There may be more information available from
[server:02392] ERROR: the remote shell (see above).
[server:02392] ERROR: The daemon exited unexpectedly with status 127.
The machines where i want to execute the process can ssh without password.
and these machines are having the identical copy of mpd.host and
..mpd.conf. When I use the command 'mpdboot -f mdp.hosts' and then
'mpdtrace -l ' I get only the current machine listing and not the listing
for other machine mentioned in 'mpd.hosts'. I have compiled and installed
the same version of mpich2 on both machines.
Kindly help
With best regards
Pravinkumar
This Message and any attachment (the "message") is intended solely for the addressees and is confidential.
If you receive this message in error, please delete it and immediately notify the sender.
Any use not in accord with its purpose, any dissemination or disclosure, either whole or partial,
is prohibited except formal approval. The internet can not guarantee the integrity of this message.
Jubilant Organosys Ltd. (and its subsidiaries) shall (will) not therefore be liable for the message if modified.
