[MPICH] MPICH2 hangs on diskless SuSE 10.2 based cluster
    Rusty Lusk
    lusk at mcs.anl.gov
    Tue Dec 19 21:59:11 CST 2006
I recommend that you follow the steps in the User's Guide starting
with the use of mpdcheck to make sure both machines are properly
configured and can communicate with one another, and start the mpd's
on these two machines "by hand" instead of going immediately to the
more scalable but less informative mpdboot.
Rusty
On Dec 20, 2006, at 6:33 AMDecember, Shaun Qualheim wrote:
> Hey everyone...
> I'm trying to figure out why I'm having an issue with running a job
> on multiple machines here.
> It worked fine with a 32-bit SuSE 9.3 based setup.
> I started it up with a 64-bit base distro and kernel...
> I can start up the process with:
> mpd &; mpiexec -n 2 process &
> and it starts with no issues...
> When I try doing that with 2 machines though...
> mpdboot -n 2 &; mpiexec -n 2 process &
> It hangs for about 5 minutes and then starts up.
> After it starts up and runs to completion, I can issue the same
> command again and it starts up right away.
> Any ideas of where to start here or what might be causing this issue?
> Thanks!
> Shaun
