[MPICH] MPICH2 hangs on diskless SuSE 10.2 based cluster
    Rajeev Thakur
    thakur at mcs.anl.gov
    Tue Dec 19 22:19:49 CST 2006
Are you using the latest release, 1.0.5?
If you want to run a job in the background, you should run it as
mpiexec -n 2 process < /dev/null &
(although I don't know if it will help in this case).
Rajeev
> -----Original Message-----
> From: owner-mpich-discuss at mcs.anl.gov
> [mailto:owner-mpich-discuss at mcs.anl.gov] On Behalf Of Shaun Qualheim
> Sent: Tuesday, December 19, 2006 7:04 PM
> To: mpich-discuss at mcs.anl.gov
> Subject: [MPICH] MPICH2 hangs on diskless SuSE 10.2 based cluster
> Hey everyone...
> I'm trying to figure out why I'm having an issue with running
> a job on
> multiple machines here.
> It worked fine with a 32-bit SuSE 9.3 based setup.
> I started it up with a 64-bit base distro and kernel...
> I can start up the process with:
> mpd &; mpiexec -n 2 process &
> and it starts with no issues...
> When I try doing that with 2 machines though...
> mpdboot -n 2 &; mpiexec -n 2 process &
> It hangs for about 5 minutes and then starts up.
> After it starts up and runs to completion, I can issue the
> same command
> again and it starts up right away.
> Any ideas of where to start here or what might be causing this issue?
> Thanks!
> Shaun
