[MPICH] MPI Program in C++ Compilation problem
Rajeev Thakur thakur at mcs.anl.gov
Tue Apr 18 17:18:38 CDT 2006
It's probably because the NFS on your machine is very slow. mpicc and mpiCC
are just simple scripts that call the real C and C++ compilers. If your
MPICH installation or code is on a slow NFS volume, it will take time to
compile.
Also, 1.2.5 is a very old version of MPICH. You should use MPICH2 instead.
Rajeev
> -----Original Message-----
> From: owner-mpich-discuss at mcs.anl.gov
> [mailto:owner-mpich-discuss at mcs.anl.gov] On Behalf Of Shekhar Tyagi
> Sent: Tuesday, April 18, 2006 1:24 PM
> To: mpich-discuss at mcs.anl.gov
> Subject: [MPICH] MPI Program in C++ Compilation problem
> Hi all
> I am new to parallel computing and working on a cluster using
> the version 1.2.5.
> I made two programs recently, one in C and the other in C++,
> the compilation of
> C program takes a lot of time while the C++ compiler never
> actually terminates
> i.e is not able to form an executable file. The sommand
> windows for the
> compilation are
>  [styagi at borelli Mpi]$ mpiCC -o hello++ hello++.cc
> nothing seems to be happening after this, command window for
> C program is
> [styagi at borelli Mpi]$ mpicc -o hello++ hello++.c
> the C program is compiled but after a very long time. Please
> help me in this
> regard so as to shorten the time for compilation and make the
> C++ compiler up
> and running.
> Shekhar
