[MPICH] Errors when running code on mpi flavor of globus: Can't read MPIRUN_HOST
vikas bhardwaj
vikas21 at gmail.com
Wed Apr 5 10:13:03 CDT 2006
I am installing mpich flavor of Globus 4.0.1 , on Dual Xeon 2.8 GHz
machine running RHEL 4 - U2. I am using mpich 1.2.7 with MVICH as
native mpi. Target is to install MPICH G2.
I am using "mpicc64" flavor of globus.
There is no problem in installation , its absolutely error free.
then i try to run a simple hello world program given at
http://www.hpclab.niu.edu/mpi/DistributedFiles/hello.c
I have properly generated makefile_header & hello.rsl files
hello.rsl is as follows
( &(resourceManagerContact="in02")
(jobtype=mpi)
(label="subjob 0")
(count=8)
(environment=(GLOBUS_DUROC_SUBJOB_INDEX 0)
(LD_LIBRARY_PATH /usr/local/globus/lib/))
(executable="/home/globus/hello/hello")
program is getting compiled without any error but when i run it using
globusrun -w -f hello.rsl
i get following error
"Can't read MPIRUN_HOST"
the mpich installation is OK as I have tested some benchmarks (Pallas)
over that ,
then why i am getting this error , the environment variables are
getting exported when doing rsh .
Please tell the details, of the reason of the error, & guide .
Thanks
Vikas Bhardwaj
