[MPICH] installing on sun. config.log attached
Rusty Lusk lusk at mcs.anl.gov
Wed Sep 28 09:00:49 CDT 2005
To install the default mpd process manager, you will need to install
Python (as the Installation Guide explains).  Python is free from
python.org and is relatively easy to install.
If you are going to run on a single machine, you can use a different
process manager, which does not require Python.  Configure with
  configure ...  --with-pm=gforker  ...
That will configure a different version of mpiexec, which works fine for
single hosts.
Rusty
Subject: Re: [MPICH] installing on sun. config.log attached
Date: Wed, 28 Sep 2005 07:35:12 -0500
> Rajeev,
> At your request, I removed all the directory created by tar (including
> the hidden subdirectory without execute permission).  I did a fresh tar,
> your recommended setenv's, and ./configure.  Results were the same.  I
> created a little c program (hello world) which compiled and ran
> successfully.
> I understand you routine build on solaris platform.  I to get much
> further on my Sun desktop (SunOS 5.9 Ultra 30) before failing because I
> do not have Python installed.   My servers (SunOS 5.6 Ultra-Enterprise)
> fail much sooner with the logs I sent you.  What experience is there
> with MPI on Enterprise systems?
> Thanks,
> Karl
> Rajeev Thakur wrote:
> >I don't know what's going on. The configure script is unable to compile a
> >simple test program. Can you create a small dummy C program and see if it
> >compiles and runs with cc. Otherwise, just do a fresh untar of the tar file
> >and try again. We routinely build on a Solaris platform, so I don't know
> >what's happening here.
> >Rajeev
> >>-----Original Message-----
> >>From: Karl Schleicher [mailto:karl at appliedgeo.com]
> >>Sent: Tuesday, September 27, 2005 3:57 PM
> >>To: Rajeev Thakur
> >>Cc: mpich-discuss at mcs.anl.gov
> >>Rajeev,
> >>I've attached the config.log.
> >>By the way I did not complete the config on my desktop Sun.
> >>It failed
> >>looking for python, which has not been installed.
> >>Karl
> >>>Could you send the config.log file?
> >>>Rajeev
> >>>>From: owner-mpich-discuss at mcs.anl.gov
> >>>>[mailto:owner-mpich-discuss at mcs.anl.gov] On Behalf Of Karl
> >>Schleicher
> >>>>Sent: Tuesday, September 27, 2005 2:00 PM
> >>>>To: Rajeev Thakur
> >>>>Subject: Re: [MPICH] Newbee having pblms installing on sun
> >>>>Rajeev,
> >>>>Results are very similar:
> >>>>Configuring MPICH2 version 1.0.2
> >>>>sourcing /home/karl/mpi/mpich2-1.0.2p1/src/pm/mpd/setup_pm
> >>>>checking for gcc... cc
> >>>>cat: cannot open confdefs.h
> >>>>checking for C compiler default output file name... Can't
> >>>>open conftest.c
> >>>>configure: error: C compiler cannot create executables
> >>>>See `config.log' for more details.
> >>>>I did complete the configuration on my desktop, but is not try the
> >>>>make.  On that computer "uname -a" produces:
> >>>>SunOS c12 5.9 Generic_118558-06 sun4u sparc SUNW,Ultra-30
> >>>>I wonder if the problem is the shared memory multi-processor
> >>>>Enterprise.  I really need to lash up several of these
> >>>>computers to work on my problem and want to use MPI to handle
> >>>>the message passing.  I already have the code multi threaded
> >>>>on one system.
> >>>>Thanks,
> >>>>Karl
> >>>>>Try specifying the Sun compilers explicitly by setting the
> >>>>environment
> >>>>>variables CC, CXX, F77, F90 as
> >>>>>setenv CC cc
> >>>>>setenv CXX CC
> >>>>>setenv F77 f77
> >>>>>Setenv F90 f90
> >>>>>Rajeev
> >>>>Schleicher
> >>>>>>Sent: Tuesday, September 27, 2005 9:28 AM
> >>>>>>To: mpich-discuss at mcs.anl.gov
> >>>>>>Subject: [MPICH] Newbee having pblms installing on sun
> >>>>>>I'm trying to install mpi on a cluster of Sun enterprise
> >>>>systems.  I
> >>>>>>want to use several of our compute servers to solve one
> >>>>>>problem.  I have
> >>>>>>tried to do a little homework before asking for help, but now I'm
> >>>>>>stuck.  I would appreciate help getting past these problem.
> >>>>>>The steps I followed are:
> >>>>>>  ftp release to my computer
> >>>>>>  gunzip -c mpich2-1.0.2p1.tar.gz | tar -xovf -
> >>>>>>  cd mpich2-1.0.2p1
> >>>>>>  ./configure |& tee configure.log
> >>>>>>Configure fails  with the log:
> >>>>>>checking for gcc... no
> >>>>>>checking for cc... cc
> >>>>>>open conftest.c
> >>>>>>I enterred "uname -a" to get:
> >>>>>>SunOS m00 5.6 Generic_105181-29 sun4u sparc SUNW,Ultra-Enterprise
> >>>>>>Some of the things I have tried are:
> >>>>>>  - building on a Linux PC.  Successful.
> >>>>>>  - building mpich-1.2.7. It hangs looking "checking for c++"
> >>>>>>  - building mpich2 on another Sun system with different
> >>>>>>os.  It hangs
> >>>>>>after:
> >>>>>>      "checking for g77... g77"
> >>>>>>  - The programmers and system administrators at my small
> >>>>>>company are
> >>>>>>unable to
> >>>>>>        to help.
> >>>>>>I have additional information that I will provide if this is
> >>>>>>insufficient.
> >>>>>>Thanks in advance for any help.
> >>>>>>Karl Schleicher
> >>>>>>Applied Geophysical Services
