[MPICH] installing on sun. config.log attached
    Karl Schleicher
    karl at appliedgeo.com
    Wed Sep 28 07:35:12 CDT 2005
Rajeev,
At your request, I removed all the directory created by tar (including
the hidden subdirectory without execute permission).  I did a fresh tar,
your recommended setenv's, and ./configure.  Results were the same.  I
created a little c program (hello world) which compiled and ran
successfully.
I understand you routine build on solaris platform.  I to get much
further on my Sun desktop (SunOS 5.9 Ultra 30) before failing because I
do not have Python installed.   My servers (SunOS 5.6 Ultra-Enterprise)
fail much sooner with the logs I sent you.  What experience is there
with MPI on Enterprise systems?
Karl
Rajeev Thakur wrote:
>I don't know what's going on. The configure script is unable to compile a
>simple test program. Can you create a small dummy C program and see if it
>compiles and runs with cc. Otherwise, just do a fresh untar of the tar file
>and try again. We routinely build on a Solaris platform, so I don't know
>what's happening here.
>Rajeev
>>-----Original Message-----
>>From: Karl Schleicher [mailto:karl at appliedgeo.com]
>>Sent: Tuesday, September 27, 2005 3:57 PM
>>To: Rajeev Thakur
>>Cc: mpich-discuss at mcs.anl.gov
>>Subject: Re: [MPICH] installing on sun. config.log attached
>>Rajeev,
>>I've attached the config.log.
>>By the way I did not complete the config on my desktop Sun.
>>It failed
>>looking for python, which has not been installed.
>>Karl
>>>Could you send the config.log file?
>>>Rajeev
>>>>From: owner-mpich-discuss at mcs.anl.gov
>>>>[mailto:owner-mpich-discuss at mcs.anl.gov] On Behalf Of Karl
>>Schleicher
>>>>Sent: Tuesday, September 27, 2005 2:00 PM
>>>>To: Rajeev Thakur
>>>>Subject: Re: [MPICH] Newbee having pblms installing on sun
>>>>Rajeev,
>>>>Results are very similar:
>>>>Configuring MPICH2 version 1.0.2
>>>>sourcing /home/karl/mpi/mpich2-1.0.2p1/src/pm/mpd/setup_pm
>>>>checking for gcc... cc
>>>>cat: cannot open confdefs.h
>>>>checking for C compiler default output file name... Can't
>>>>open conftest.c
>>>>configure: error: C compiler cannot create executables
>>>>See `config.log' for more details.
>>>>I did complete the configuration on my desktop, but is not try the
>>>>make.  On that computer "uname -a" produces:
>>>>SunOS c12 5.9 Generic_118558-06 sun4u sparc SUNW,Ultra-30
>>>>I wonder if the problem is the shared memory multi-processor
>>>>Enterprise.  I really need to lash up several of these
>>>>computers to work on my problem and want to use MPI to handle
>>>>the message passing.  I already have the code multi threaded
>>>>on one system.
>>>>Thanks,
>>>>Karl
>>>>>Try specifying the Sun compilers explicitly by setting the
>>>>environment
>>>>>variables CC, CXX, F77, F90 as
>>>>>setenv CC cc
>>>>>setenv CXX CC
>>>>>setenv F77 f77
>>>>>Setenv F90 f90
>>>>>Rajeev
>>>>Schleicher
>>>>>>Sent: Tuesday, September 27, 2005 9:28 AM
>>>>>>To: mpich-discuss at mcs.anl.gov
>>>>>>Subject: [MPICH] Newbee having pblms installing on sun
>>>>>>I'm trying to install mpi on a cluster of Sun enterprise
>>>>systems.  I
>>>>>>want to use several of our compute servers to solve one
>>>>>>problem.  I have
>>>>>>tried to do a little homework before asking for help, but now I'm
>>>>>>stuck.  I would appreciate help getting past these problem.
>>>>>>The steps I followed are:
>>>>>>  ftp release to my computer
>>>>>>  gunzip -c mpich2-1.0.2p1.tar.gz | tar -xovf -
>>>>>>  cd mpich2-1.0.2p1
>>>>>>  ./configure |& tee configure.log
>>>>>>Configure fails  with the log:
>>>>>>checking for gcc... no
>>>>>>checking for cc... cc
>>>>>>open conftest.c
>>>>>>I enterred "uname -a" to get:
>>>>>>SunOS m00 5.6 Generic_105181-29 sun4u sparc SUNW,Ultra-Enterprise
>>>>>>Some of the things I have tried are:
>>>>>>  - building on a Linux PC.  Successful.
>>>>>>  - building mpich-1.2.7. It hangs looking "checking for c++"
>>>>>>  - building mpich2 on another Sun system with different
>>>>>>os.  It hangs
>>>>>>after:
>>>>>>      "checking for g77... g77"
>>>>>>  - The programmers and system administrators at my small
>>>>>>company are
>>>>>>unable to
>>>>>>        to help.
>>>>>>I have additional information that I will provide if this is
>>>>>>insufficient.
>>>>>>Thanks in advance for any help.
>>>>>>Karl Schleicher
>>>>>>Applied Geophysical Services
