[MPICH] installing on sun. config.log attached
Karl Schleicher karl at appliedgeo.com
Wed Sep 28 11:31:37 CDT 2005
Rusty or Rajeev,
I am working on installing Python.  I am still stuck with my original
problem that configure is failing much earlier.
I'm trying to install mpi on a cluster of Sun enterprise systems. I want
to use several of our compute servers to solve one problem.
The steps I followed are:
 ftp release to my computer
gunzip -c mpich2-1.0.2p1.tar.gz | tar -xovf -
cd mpich2-1.0.2p1
./configure |& tee configure.log
Configure fails  with the log:
Configuring MPICH2 version 1.0.2
sourcing /home/karl/mpi/mpich2-1.0.2p1/src/pm/mpd/setup_pm
checking for gcc... no
checking for cc... cc
cat: cannot open confdefs.h
checking for C compiler default output file name... Can't
open conftest.c
configure: error: C compiler cannot create executables
See `config.log' for more details.
I enterred "uname -a" to get:
SunOS m00 5.6 Generic_105181-29 sun4u sparc SUNW,Ultra-Enterprise
I have tried working on other systems to understand the problem, but they are tangents.  I followed Rajeev suggestions to set environment variables, rerun the tar extraction, test the c compiler.
Thanks in advance,
Karl Schleicher
Applied Geophysical Services
Rusty Lusk wrote:
>To install the default mpd process manager, you will need to install
>Python (as the Installation Guide explains).  Python is free from
>python.org and is relatively easy to install.
>If you are going to run on a single machine, you can use a different
>process manager, which does not require Python.  Configure with
>  configure ...  --with-pm=gforker  ...
>That will configure a different version of mpiexec, which works fine for
>single hosts.
>Regards,
>Rusty
>From: Karl Schleicher <karl at appliedgeo.com>
>Subject: Re: [MPICH] installing on sun. config.log attached
>Date: Wed, 28 Sep 2005 07:35:12 -0500
>>Rajeev,
>>At your request, I removed all the directory created by tar (including
>>the hidden subdirectory without execute permission).  I did a fresh tar,
>>your recommended setenv's, and ./configure.  Results were the same.  I
>>created a little c program (hello world) which compiled and ran
>>successfully.
>>I understand you routine build on solaris platform.  I to get much
>>further on my Sun desktop (SunOS 5.9 Ultra 30) before failing because I
>>do not have Python installed.   My servers (SunOS 5.6 Ultra-Enterprise)
>>fail much sooner with the logs I sent you.  What experience is there
>>with MPI on Enterprise systems?
>>Thanks,
>>Karl
>>Rajeev Thakur wrote:
>>>I don't know what's going on. The configure script is unable to compile a
>>>simple test program. Can you create a small dummy C program and see if it
>>>compiles and runs with cc. Otherwise, just do a fresh untar of the tar file
>>>and try again. We routinely build on a Solaris platform, so I don't know
>>>what's happening here.
>>>Rajeev
>>>>-----Original Message-----
>>>>From: Karl Schleicher [mailto:karl at appliedgeo.com]
>>>>Sent: Tuesday, September 27, 2005 3:57 PM
>>>>To: Rajeev Thakur
>>>>Cc: mpich-discuss at mcs.anl.gov
>>>>Rajeev,
>>>>I've attached the config.log.
>>>>By the way I did not complete the config on my desktop Sun.
>>>>It failed
>>>>looking for python, which has not been installed.
>>>>Karl
>>>>>Could you send the config.log file?
>>>>>Rajeev
>>>>>>From: owner-mpich-discuss at mcs.anl.gov
>>>>>>[mailto:owner-mpich-discuss at mcs.anl.gov] On Behalf Of Karl
>>>>Schleicher
>>>>>>Sent: Tuesday, September 27, 2005 2:00 PM
>>>>>>To: Rajeev Thakur
>>>>>>Subject: Re: [MPICH] Newbee having pblms installing on sun
>>>>>>Rajeev,
>>>>>>Results are very similar:
>>>>>>checking for gcc... cc
>>>>>>open conftest.c
>>>>>>I did complete the configuration on my desktop, but is not try the
>>>>>>make.  On that computer "uname -a" produces:
>>>>>>SunOS c12 5.9 Generic_118558-06 sun4u sparc SUNW,Ultra-30
>>>>>>I wonder if the problem is the shared memory multi-processor
>>>>>>Enterprise.  I really need to lash up several of these
>>>>>>computers to work on my problem and want to use MPI to handle
>>>>>>the message passing.  I already have the code multi threaded
>>>>>>on one system.
>>>>>>Thanks,
>>>>>>Karl
>>>>>>>Try specifying the Sun compilers explicitly by setting the
>>>>>>environment
>>>>>>>variables CC, CXX, F77, F90 as
>>>>>>>setenv CC cc
>>>>>>>setenv CXX CC
>>>>>>>setenv F77 f77
>>>>>>>Setenv F90 f90
>>>>>>>Rajeev
>>>>>>Schleicher
>>>>>>>>Sent: Tuesday, September 27, 2005 9:28 AM
>>>>>>>>To: mpich-discuss at mcs.anl.gov
>>>>>>>>Subject: [MPICH] Newbee having pblms installing on sun
>>>>>>systems.  I
>>>>>>>>want to use several of our compute servers to solve one
>>>>>>>>problem.  I have
>>>>>>>>tried to do a little homework before asking for help, but now I'm
>>>>>>>>stuck.  I would appreciate help getting past these problem.
>>>>>>>> cd mpich2-1.0.2p1
>>>>>>>>open conftest.c
>>>>>>>>Some of the things I have tried are:
>>>>>>>> - building on a Linux PC.  Successful.
>>>>>>>> - building mpich-1.2.7. It hangs looking "checking for c++"
>>>>>>>> - building mpich2 on another Sun system with different
>>>>>>>>os.  It hangs
>>>>>>>>after:
>>>>>>>>     "checking for g77... g77"
>>>>>>>> - The programmers and system administrators at my small
>>>>>>>>company are
>>>>>>>>unable to
>>>>>>>>       to help.
>>>>>>>>I have additional information that I will provide if this is
>>>>>>>>insufficient.
>>>>>>>>Thanks in advance for any help.
>>>>>>>>Karl Schleicher
