[MPICH] installing on sun. config.log attached
    Rajeev Thakur
    thakur at mcs.anl.gov
    Tue Sep 27 16:05:57 CDT 2005
I don't know what's going on. The configure script is unable to compile a
simple test program. Can you create a small dummy C program and see if it
compiles and runs with cc. Otherwise, just do a fresh untar of the tar file
and try again. We routinely build on a Solaris platform, so I don't know
what's happening here.
Rajeev
> -----Original Message-----
> From: Karl Schleicher [mailto:karl at appliedgeo.com]
> Sent: Tuesday, September 27, 2005 3:57 PM
> To: Rajeev Thakur
> Cc: mpich-discuss at mcs.anl.gov
> Subject: Re: [MPICH] installing on sun. config.log attached
> Rajeev,
> I've attached the config.log.
> By the way I did not complete the config on my desktop Sun.
> It failed
> looking for python, which has not been installed.
> Karl
> Rajeev Thakur wrote:
> >Could you send the config.log file?
> >Rajeev
> >>From: owner-mpich-discuss at mcs.anl.gov
> >>[mailto:owner-mpich-discuss at mcs.anl.gov] On Behalf Of Karl
> Schleicher
> >>Sent: Tuesday, September 27, 2005 2:00 PM
> >>To: Rajeev Thakur
> >>Subject: Re: [MPICH] Newbee having pblms installing on sun
> >>Rajeev,
> >>Results are very similar:
> >>Configuring MPICH2 version 1.0.2
> >>sourcing /home/karl/mpi/mpich2-1.0.2p1/src/pm/mpd/setup_pm
> >>checking for gcc... cc
> >>cat: cannot open confdefs.h
> >>checking for C compiler default output file name... Can't
> >>open conftest.c
> >>configure: error: C compiler cannot create executables
> >>See `config.log' for more details.
> >>I did complete the configuration on my desktop, but is not try the
> >>make.  On that computer "uname -a" produces:
> >>SunOS c12 5.9 Generic_118558-06 sun4u sparc SUNW,Ultra-30
> >>I wonder if the problem is the shared memory multi-processor
> >>Enterprise.  I really need to lash up several of these
> >>computers to work on my problem and want to use MPI to handle
> >>the message passing.  I already have the code multi threaded
> >>on one system.
> >>Thanks,
> >>Karl
> >>>Try specifying the Sun compilers explicitly by setting the
> >>environment
> >>>variables CC, CXX, F77, F90 as
> >>>setenv CC cc
> >>>setenv CXX CC
> >>>setenv F77 f77
> >>>Setenv F90 f90
> >>>Rajeev
> >>Schleicher
> >>>>Sent: Tuesday, September 27, 2005 9:28 AM
> >>>>To: mpich-discuss at mcs.anl.gov
> >>>>Subject: [MPICH] Newbee having pblms installing on sun
> >>>>I'm trying to install mpi on a cluster of Sun enterprise
> >>systems.  I
> >>>>want to use several of our compute servers to solve one
> >>>>problem.  I have
> >>>>tried to do a little homework before asking for help, but now I'm
> >>>>stuck.  I would appreciate help getting past these problem.
> >>>>The steps I followed are:
> >>>>   ftp release to my computer
> >>>>   gunzip -c mpich2-1.0.2p1.tar.gz | tar -xovf -
> >>>>   cd mpich2-1.0.2p1
> >>>>   ./configure |& tee configure.log
> >>>>Configure fails  with the log:
> >>>>checking for gcc... no
> >>>>checking for cc... cc
> >>>>open conftest.c
> >>>>I enterred "uname -a" to get:
> >>>>SunOS m00 5.6 Generic_105181-29 sun4u sparc SUNW,Ultra-Enterprise
> >>>>Some of the things I have tried are:
> >>>>   - building on a Linux PC.  Successful.
> >>>>   - building mpich-1.2.7. It hangs looking "checking for c++"
> >>>>   - building mpich2 on another Sun system with different
> >>>>os.  It hangs
> >>>>after:
> >>>>       "checking for g77... g77"
> >>>>   - The programmers and system administrators at my small
> >>>>company are
> >>>>unable to
> >>>>         to help.
> >>>>I have additional information that I will provide if this is
> >>>>insufficient.
> >>>>Thanks in advance for any help.
> >>>>Karl Schleicher
> >>>>Applied Geophysical Services
