[MPICH] installing on sun. config.log attached
Karl Schleicher
karl at appliedgeo.com
Tue Sep 27 15:56:46 CDT 2005
Rajeev,
I've attached the config.log.
By the way I did not complete the config on my desktop Sun. It failed
looking for python, which has not been installed.
Karl
Rajeev Thakur wrote:
>Could you send the config.log file?
>Rajeev
>>-----Original Message-----
>>From: owner-mpich-discuss at mcs.anl.gov
>>[mailto:owner-mpich-discuss at mcs.anl.gov] On Behalf Of Karl Schleicher
>>Sent: Tuesday, September 27, 2005 2:00 PM
>>To: Rajeev Thakur
>>Cc: mpich-discuss at mcs.anl.gov
>>Subject: Re: [MPICH] Newbee having pblms installing on sun
>>Rajeev,
>>Results are very similar:
>>Configuring MPICH2 version 1.0.2
>>sourcing /home/karl/mpi/mpich2-1.0.2p1/src/pm/mpd/setup_pm
>>checking for gcc... cc
>>cat: cannot open confdefs.h
>>checking for C compiler default output file name... Can't
>>open conftest.c
>>configure: error: C compiler cannot create executables
>>See `config.log' for more details.
>>I did complete the configuration on my desktop, but is not try the
>>make. On that computer "uname -a" produces:
>>SunOS c12 5.9 Generic_118558-06 sun4u sparc SUNW,Ultra-30
>>I wonder if the problem is the shared memory multi-processor
>>Enterprise. I really need to lash up several of these
>>computers to work on my problem and want to use MPI to handle
>>the message passing. I already have the code multi threaded
>>on one system.
>>Thanks,
>>Karl
>>>Try specifying the Sun compilers explicitly by setting the
>>environment
>>>variables CC, CXX, F77, F90 as
>>>setenv CC cc
>>>setenv CXX CC
>>>setenv F77 f77
>>>Setenv F90 f90
>>>Rajeev
>>Schleicher
>>>>Sent: Tuesday, September 27, 2005 9:28 AM
>>>>To: mpich-discuss at mcs.anl.gov
>>>>Subject: [MPICH] Newbee having pblms installing on sun
>>>>I'm trying to install mpi on a cluster of Sun enterprise
>>systems. I
>>>>want to use several of our compute servers to solve one
>>>>problem. I have
>>>>tried to do a little homework before asking for help, but now I'm
>>>>stuck. I would appreciate help getting past these problem.
>>>>The steps I followed are:
>>>> ftp release to my computer
>>>> gunzip -c mpich2-1.0.2p1.tar.gz | tar -xovf -
>>>> cd mpich2-1.0.2p1
>>>> ./configure |& tee configure.log
>>>>Configure fails with the log:
>>>>checking for gcc... no
>>>>checking for cc... cc
>>>>open conftest.c
>>>>I enterred "uname -a" to get:
>>>>SunOS m00 5.6 Generic_105181-29 sun4u sparc SUNW,Ultra-Enterprise
>>>>Some of the things I have tried are:
>>>> - building on a Linux PC. Successful.
>>>> - building mpich-1.2.7. It hangs looking "checking for c++"
>>>> - building mpich2 on another Sun system with different
>>>>os. It hangs
>>>>after:
>>>> "checking for g77... g77"
>>>> - The programmers and system administrators at my small
>>>>company are
>>>>unable to
>>>> to help.
>>>>I have additional information that I will provide if this is
>>>>insufficient.
>>>>Thanks in advance for any help.
>>>>Karl Schleicher
>>>>Applied Geophysical Services
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20050927/964b30a8/attachment.diff>
