[MPICH] Two problems regarding MPICH2 on Macintosh
Rajeev Thakur
thakur at mcs.anl.gov
Mon Oct 24 12:53:33 CDT 2005
smpd has not been tested on the Mac. It has been tested on Windows and
Linux.
When using the -ssh option to mpdcheck, it assumes that mpdcheck.py is in
the same directory on all machines. On the other hand, if you follow the
directions in the install.pdf guide (item 5, pg 24), it has you actually
login to the problematic machines and run there directly rather than via
ssh. Then mpdcheck can be wherever you like. The guide suggests that you
pick 2 machines which are having issues and debug using them. It asks that
you run mpdcheck on one as a server and the other as a client, and then
reverse the roles, etc.
Rajeev
> -----Original Message-----
> From: owner-mpich-discuss at mcs.anl.gov
> [mailto:owner-mpich-discuss at mcs.anl.gov] On Behalf Of Yu-Cheng Chou
> Sent: Friday, October 21, 2005 4:25 PM
> To: mpich-discuss at mcs.anl.gov
> Subject: [MPICH] Two problems regarding MPICH2 on Macintosh
> Hi,
> (1)
> When I ran cpi with smpd on a macintosh machine (Mac OS 10.4, Darwin
> Kernel Version 8.2.0), error messages shown below occurred.
> > mpiexec -n 1 cpi
> MPIDU_Sock_wait failed,
> sock error: generic socket failure, error stack:
> MPIDU_Sock_wait(269): sock contains an invalid file descriptor
> (set=1,sock=16777217,fd=0:0)
> state machine failed.
> The firewall was off when I ran mpiexec.
> How should I fix it?
> (2)
> I ran mpdcheck on two machines including a linux and a macintosh
> platforms, and I got the output below.
> /home/ycchou> mpdcheck -f mpd.hosts -ssh
> ycchou at iel2's password:
> client on ielmac failed to access the server
> here is the output:
> bash: line 1: /home/ycchou/mpich2_mpd/bin/mpdcheck.py: No
> such file or
> directory
> How can I specify the path of mpdcheck.py for macintosh?
> The file is located in /Users/ycchou/mpich2_mpd/bin/mpdcheck.py
> BTW, it seems like no one from the MPICH2 group responded the first
> question that I posted before. Just wondering that if
> MPICH2's smpd works
> on macintosh.
> Thanks
