[MPICH] MPICH2, FORTRAN disabled, yields switch-case collision
Fritz Anderson
fritza at uchicago.edu
Fri Oct 21 16:28:51 CDT 2005
So I'm still working on compiling MPICH2, 1.0.2p1, using the
configuration
CCFLAGS='-arch ppc64' LDFLAGS='-arch ppc64' CXXFLAGS='-arch ppc64' ./
configure --disable-f77 --disable-f90 --prefix='/usr/local' --with-
pm=mpd:gforker
Note that I have both FORTRAN dialects disabled. This causes mpi.h to
have the following #defines:
#define MPI_COMPLEX ((MPI_Datatype)MPI_DATATYPE_NULL)
#define MPI_DOUBLE_COMPLEX ((MPI_Datatype)MPI_DATATYPE_NULL)
#define MPI_LOGICAL ((MPI_Datatype)MPI_DATATYPE_NULL)
#define MPI_DATATYPE_NULL ((MPI_Datatype)0x0c000000)
Now consider the function CollChk_basic_value() in same_dtype in the
mce2 tree:
unsigned int CollChk_basic_value(MPI_Datatype type)
switch (type) {
MPI_Datatype's that return 0x0 are as if they are being
skipped/ignored in the comparison of any 2 MPI_Datatypes.
case MPI_DATATYPE_NULL :
case MPI_UB :
case MPI_LB :
return 0x0;
case MPI_COMPLEX :
return 0x101;
case MPI_DOUBLE_COMPLEX :
return 0x103;
case MPI_LOGICAL :
return 0x105;
The compiler quite reasonably chokes, because the latter cases have
the same value as the first.
I find that suppressing the --disable-f77 and -f90 flags does no
good, probably because the configuration script notices that I don't
have a FORTRAN compiler.
Is there a way around this? Are users without FORTRAN required to do
without MPE? Or is there a configuration preprocessor symbol for the
no-FORTRAN condition so I can #if out the erring cases?
-- F
