[MPICH] MPICH2, FORTRAN disabled, yields switch-case collision
Rajeev Thakur thakur at mcs.anl.gov
Fri Oct 21 17:06:08 CDT 2005
That might be a problem in the 1.0.2p1 release, but it has been fixed in our
current source code. You can disable just the collective checking library
(not all of MPE) with the option --disable-collchk.
Rajeev
> -----Original Message-----
> From: owner-mpich-discuss at mcs.anl.gov
> [mailto:owner-mpich-discuss at mcs.anl.gov] On Behalf Of Fritz Anderson
> Sent: Friday, October 21, 2005 4:29 PM
> To: mpich-discuss at mcs.anl.gov
> Subject: [MPICH] MPICH2, FORTRAN disabled, yields switch-case
> collision
> So I'm still working on compiling MPICH2, 1.0.2p1, using the
> configuration
> CCFLAGS='-arch ppc64' LDFLAGS='-arch ppc64' CXXFLAGS='-arch ppc64' ./
> configure --disable-f77 --disable-f90 --prefix='/usr/local' --with-
> pm=mpd:gforker
> Note that I have both FORTRAN dialects disabled. This causes
> mpi.h to
> have the following #defines:
> #define MPI_COMPLEX           ((MPI_Datatype)MPI_DATATYPE_NULL)
> #define MPI_DOUBLE_COMPLEX    ((MPI_Datatype)MPI_DATATYPE_NULL)
> #define MPI_LOGICAL           ((MPI_Datatype)MPI_DATATYPE_NULL)
> #define MPI_DATATYPE_NULL  ((MPI_Datatype)0x0c000000)
> Now consider the function CollChk_basic_value() in same_dtype in the
> mce2 tree:
> unsigned int CollChk_basic_value(MPI_Datatype type)
>      switch (type) {
>             MPI_Datatype's that return 0x0 are as if they are being
>             skipped/ignored in the comparison of any 2 MPI_Datatypes.
>          case MPI_DATATYPE_NULL :
>          case MPI_UB :
>          case MPI_LB :
>              return 0x0;
>          case MPI_COMPLEX :
>              return 0x101;
>          case MPI_DOUBLE_COMPLEX :
>              return 0x103;
>          case MPI_LOGICAL :
>              return 0x105;
> The compiler quite reasonably chokes, because the latter cases have
> the same value as the first.
> I find that suppressing the --disable-f77 and -f90 flags does no
> good, probably because the configuration script notices that I don't
> have a FORTRAN compiler.
> Is there a way around this? Are users without FORTRAN required to do
> without MPE? Or is there a configuration preprocessor symbol for the
> no-FORTRAN condition so I can #if out the erring cases?
>      -- F
