Experiences with MPICH2 and C++
philip lavers psl02 at uow.edu.au
Thu Jun 9 02:56:18 CDT 2005
Hello MPICH2 people,
The writer is self-taught in all aspects of computing, and relates the
following a) in case it is helpful to other amateurs and b) in case
others more versed in the field can lend advice.
The current cluster is one dual opteron platform and three single
athlon64 platforms. The switch is NetGear Gigabit.
The best "bang for buck" probably comes from 939 pin athlon64 3.2 or
higher.
At one stage or another every machine has operated on Solaris 10 (x86),
Mandrake Linux 64 10.1 and FreeBSD 64 5.3.
All these operating systems are impressive, but each has shortcomings -
e.g. the Linux did not see the SATA disk, Tfe FreeBSD does not see some
motherboard network ports, Solaris did not see the ultra-wide scsi etc.etc.
MPICH2 installed and worked fine on all OSs. Programming was in C++
compiled with gcc. SunStudio10 compilers were also tested and worked
better than gcc under Solaris on any given machine.
The current project is simulating the behaviour of short magnetic
vortices in 2D using a deterministic potential and a stochastic term.
The force calculation and integration loop adapts well for
parallelisation. A subtle point is that the stochastics( ran2() and
gasdev() from Numerical Recipes in C++) need to be seeded separately (ie
seed+=myid;) to avoid unintended correlations. Both opteron processors
can be induced to work simply by making sure that mpiexec -n N is such
that at least two processes will be allocated to that machine (whose
kernel was compiled with SMP).
The performance is fine, and encourages me to build more one-processor
nodes, because for many vortices (say >200) scaling is steep and roughly
linear.
Here are the questions and observation:
1. How do I get graphics with Xorg ?
by the way, the examples for Section 3.10 of the book "Using MPI",
downloaded from the sources in Appendix D,  do not have the graphics
routines.
I got graphical output by going to an old 32 bit machine that had
Mandrake 9.1 and XFree86, but my 64 bit machines with Xorg give error
messages.
At the moment I am stuck with making plot files on process 0 and using
gnuplot to show movies of the simulation. This seems clumsy.
2. Big puzzle:
I have gcc 3.4.2 on both FreeBSD and Linux.
the makefile says:
CFLAGS=-g -pg $(INCLUDES) -ffast-math  -O3 -march=athlon64
and everything is identical on the HD that has FreeBSD and the HD that
has Mandrake 10.1.
I can test a single machines performance with mpiexec -n 1 etc. on that
machine.
For exactly the same simulation on exactlty the same machine (athlon64
3.2) for 50 vortices and 10000 time steps, the FreeBSD machine took 112
seconds.
When I loaded Linux it took 369 seconds.
On the opteron machine (march=opteron) the figures were FreeBSD 152
seconds, Linux 555 seconds.
Linux was supposed to be fast??
For this reason I plan to standardise on FreeBSD for the remaining nodes
when I can afford them, but I would welcome input from knowledgeable
Linux users.
Philip Lavers
