Unable to compile 64-bit MPICH under Solaris 9
    Alexander Spiegel
    spiegel at rz.rwth-aachen.de
    Thu Jun  9 08:30:54 CDT 2005
with this configuration we could install MPICH2 1.0.1 on our SunFire
with Solaris 9:
CC="cc -xarch=generic64"
F77="f77 -xarch=generic64"
F90="f90 -xarch=generic64"
configure --enable-f90 --with-device=ch3:ssm --enable-romio
--enable-debuginfo --enable-cxx
And with mpd as default process manager.
with regards
Alex Spiegel
Mike Newton wrote:
> Hopefully someone can point to a solution for a problem I'm having.
> I am trying to compile a 64-bit version of MPICH with limited success.
> My environment consists of a 12 CPU domain on a Sun 12K running Solaris
> 9. I'm using Sun's Studio Pro compilers (C and Fortran).
> I have the following environment variables set:
> CC=/opt/SUNWspro/bin/cc
> FC=/opt/SUNWspro/bin/f77
> F77=/opt/SUNWspro/bin/f77
> F90=/opt/SUNWspro/bin/f90
> CFLAGS="-xarch=v9b"
> FFLAGS="-xarch=v9b"
> I've downloaded both MPICH 1.2.6 and MPICH2 1.0.1. I've gotten different
> errors, but same results, no 64-bit C and Fortran.
> I tried compiling MPICH 1.2.6 with the following configure.
> configure --with-arch=solaris --with-device=ch_shmem \
>               --with-common-prefix=/usr/local/mpich-1.2.6 \
>               --prefix=/usr/local/mpich-1.2.6/ch_shmem64
> If I unset the CFLAGS and FFLAGS a 32-bit version compiles fine. If I
> set the flags then only a 64-bit C version is built and the Fortran is
> skipped. I get the following lines when running configure:
> Warning: Fortran programs cannot be linked with the C libraries
> Fortran support being turned off
> So I thought I would give MPICH2 a run at compiling. I ran configure
> with the following options:
> configure --prefix=/usr/local/mpich2-1.0.1 --enable-f77 \
> --with-device=ch3:shm --with-pm=gforker
> configure runs fine,but during the make the following error is thrown:
> "shm.c", line 15: cannot find include file: <sys/ptrace.h>
> "shm.c", line 1580: warning: statement not reached
> cc: acomp failed for shm.c
> If I remove --with-device=ch3:shm and run configure and make again, the
> "pmiport.c", line 79: warning: implicit function declaration:
> MPIU_Error_printf
> "pmiport.c", line 86: warning: implicit function declaration: bzero
> "pmiport.c", line 99: warning: implicit function declaration:
> MPIU_Internal_sys_error_printf
> "pmiport.c", line 135: warning: implicit function declaration:
> MPIE_GetMyHostName
> "pmiport.c", line 190: warning: implicit function declaration:
> PMI_Init_port_connection
> ar cr libmpiexec.a cmnargs.o process.o ioloop.o pmiserv.o labelout.o
> env.o newsession.o rm.o pmiport.o
> ranlib libmpiexec.a
> /opt/SUNWspro/bin/cc  -o mpiexec mpiexec.o  -L../util -lmpiexec \
> -L../../../lib -lmpich -lnsl -lsocket
> ld: fatal: file mpiexec.o: wrong ELF class: ELFCLASS64
> ld: fatal: File processing errors. No output written to mpiexec
> I then removed the --with-pm=gforker and ran configure and make, and I
> was able to get a good compile. It seems inefficient, however to have to
> run the mpd process with sockets instead of using shared memory and the
> forker process manager.
