[MOAB-dev] [CELS WordPress Sites] Installation of Moab on MacOS 26.1
Christophe-Alexandre Chalons-Mouriesse
christophealexandrechalons at gmail.com
Mon Dec 8 11:37:26 CST 2025
Dear Vijay,
You will find attached the files that you requested plus the make file. It
looks like it is failing during the make install.
==> *make install*
Last 15 lines from
/Users/christophechalons/Library/Logs/Homebrew/moab/03.make.log:
../moab/Range.hpp:282:16: error: unknown type name 'EntityHandle'
282 | inline const EntityHandle& back() const;
../moab/Range.hpp:284:3: error: unknown type name 'EntityHandle'
284 | EntityHandle pop_front();
../moab/Range.hpp:286:3: error: unknown type name 'EntityHandle'
286 | EntityHandle pop_back();
fatal error: too many errors emitted, stopping now [-ferror-limit=]
20 errors generated.
make[3]: *** [ReadNASTRAN.lo] Error 1
make[2]: *** [install-recursive] Error 1
make[1]: *** [install-recursive] Error 1
make: *** [install-recursive] Error 1
I have uninstalled my homebrew and reinstalled it to be sure then I have
updated and upgraded...
==> *Updating Homebrew...*
Already up-to-date.
Christophes-MacBook-Pro:Homebrew christophechalons$ brew upgrade
Christophe
Le lun. 8 déc. 2025 à 16:18, Mahadevan, Vijay S. <mahadevan at anl.gov> a
écrit :
> Dear Christophe,
> I don’t quite understand the error below. The link is perhaps garbled. Did
> your autoreconf command fail? Can you verify that your home-brew is up to
> date? Please do send the autoreconf.log file so that we can take a closer
> look.
> Also, you should not be using 5.0.0. That version is probably a decade
> old! Please update to 5.6.0.
> Best,
> Vijay
> *From: *Christophe Chalons <christophealexandrechalons at gmail.com>
> *Date: *Monday, December 8, 2025 at 09:02
> *To: *Mahadevan, Vijay S. <mahadevan at anl.gov>
> *Subject: *[CELS WordPress Sites] Installation of Moab on MacOS 26.1
> [You don't often get email from christophealexandrechalons at gmail.com.
> Learn why this is important at
> https://urldefense.us/v3/__https://aka.ms/LearnAboutSenderIdentification__;!!G_uCfscf7eWS!ZMM4TXh8aktS3irDntQhQVdejZh_8lgcgBYiJAkuJDjJVxMSuu5Q_gKHkkesD8j88FMAyQYsyfLN2ZGf1f5Mmhgt7bTeOjM$ ]
> Hello,
> When I try the command 'brew install moab' I have the following issue :
> Christophes-MacBook-Pro:Homebrew christophechalons$ brew install moab
> ==> Fetching downloads for: moab
> ✔︎ Formula moab
> (5.0.0)
> [Verifying 11.9MB/ 11.9MB]
> ==> Installing moab from brewsci/science
> ==> autoreconf -fi
> Last 15 lines from
> /Users/christophechalons/Library/Logs/Homebrew/moab/01.autoreconf.log:
> 2025-12-08 13:53:52 +0000
> autoreconf
> -fi
> If reporting this issue please do so at (not Homebrew/* repositories):
> https://urldefense.us/v3/__https://gcc02.safelinks.protection.outlook.com/?url=https*3A*2F*2Fgithub.com*2Fbrewsci*2Fhomebrew-science*2Fissues&data=05*7C02*7Cmahadevan*40anl.gov*7C46294d742ff849242c5208de36625ff0*7C0cfca18525f749e38ae7704d5326e285*7C0*7C0*7C639007993298704390*7CUnknown*7CTWFpbGZsb3d8eyJFbXB0eU1hcGkiOnRydWUsIlYiOiIwLjAuMDAwMCIsIlAiOiJXaW4zMiIsIkFOIjoiTWFpbCIsIldUIjoyfQ*3D*3D*7C80000*7C*7C*7C&sdata=mlg6B1pE8EqTkXHjg34pgaENA*2B8b48*2Bl6jQf1IQuH7E*3D&reserved=0__;JSUlJSUlJSUlJSUlJSUlJSUlJSUlJSUlJQ!!G_uCfscf7eWS!ZMM4TXh8aktS3irDntQhQVdejZh_8lgcgBYiJAkuJDjJVxMSuu5Q_gKHkkesD8j88FMAyQYsyfLN2ZGf1f5MmhgteiyGA_A$
> <https://urldefense.us/v3/__https://github.com/brewsci/homebrew-science/issues__;!!G_uCfscf7eWS!ZMM4TXh8aktS3irDntQhQVdejZh_8lgcgBYiJAkuJDjJVxMSuu5Q_gKHkkesD8j88FMAyQYsyfLN2ZGf1f5MmhgtDfIYFqw$ >
> I don't understand why...I tried to remove the
> /Users/christophechalons/Library/Logs/Homebrew/moab directory but to no
> avail.
> Thank you in advance for your help,
> Regards,
> Christophe Chalons
