[MOAB-dev] [CELS WordPress Sites] Installation of Moab on MacOS 26.1
Mahadevan, Vijay S. mahadevan at anl.gov
Mon Dec 8 09:17:51 CST 2025
Dear Christophe,
I don’t quite understand the error below. The link is perhaps garbled. Did your autoreconf command fail? Can you verify that your home-brew is up to date? Please do send the autoreconf.log file so that we can take a closer look.
Also, you should not be using 5.0.0. That version is probably a decade old! Please update to 5.6.0.
Best,
Vijay
From: Christophe Chalons <christophealexandrechalons at gmail.com>
Date: Monday, December 8, 2025 at 09:02
To: Mahadevan, Vijay S. <mahadevan at anl.gov>
Subject: [CELS WordPress Sites] Installation of Moab on MacOS 26.1
[You don't often get email from christophealexandrechalons at gmail.com. Learn why this is important at https://urldefense.us/v3/__https://aka.ms/LearnAboutSenderIdentification__;!!G_uCfscf7eWS!aWpmBWM1MgJ8DPElpy-lA2F39Xv8RBbhcGeURwxM7amRoqfGtKyFpqaRb0DuPM3p4S1O_EtkBZ7dpDuFG0QUZMw$  ]
Hello,
When I try the command 'brew install moab' I have the following issue :
Christophes-MacBook-Pro:Homebrew christophechalons$ brew install moab
==> Fetching downloads for: moab
✔︎ Formula moab (5.0.0)        [Verifying    11.9MB/ 11.9MB]
==> Installing moab from brewsci/science
==> autoreconf -fi
Last 15 lines from /Users/christophechalons/Library/Logs/Homebrew/moab/01.autoreconf.log:
2025-12-08 13:53:52 +0000
autoreconf
-fi
If reporting this issue please do so at (not Homebrew/* repositories):
  https://urldefense.us/v3/__https://gcc02.safelinks.protection.outlook.com/?url=https*3A*2F*2Fgithub.com*2Fbrewsci*2Fhomebrew-science*2Fissues&data=05*7C02*7Cmahadevan*40anl.gov*7C46294d742ff849242c5208de36625ff0*7C0cfca18525f749e38ae7704d5326e285*7C0*7C0*7C639007993298704390*7CUnknown*7CTWFpbGZsb3d8eyJFbXB0eU1hcGkiOnRydWUsIlYiOiIwLjAuMDAwMCIsIlAiOiJXaW4zMiIsIkFOIjoiTWFpbCIsIldUIjoyfQ*3D*3D*7C80000*7C*7C*7C&sdata=mlg6B1pE8EqTkXHjg34pgaENA*2B8b48*2Bl6jQf1IQuH7E*3D&reserved=0__;JSUlJSUlJSUlJSUlJSUlJSUlJSUlJSUlJQ!!G_uCfscf7eWS!aWpmBWM1MgJ8DPElpy-lA2F39Xv8RBbhcGeURwxM7amRoqfGtKyFpqaRb0DuPM3p4S1O_EtkBZ7dpDuFAJYLEBg$ <https://urldefense.us/v3/__https://gcc02.safelinks.protection.outlook.com/?url=https*3A*2F*2Fgithub.com*2Fbrewsci*2Fhomebrew-science*2Fissues&data=05*7C02*7Cmoab-dev*40mcs.anl.gov*7Ca259d9875929494ea48308de366cfcc3*7C0cfca18525f749e38ae7704d5326e285*7C0*7C0*7C639008038888524650*7CUnknown*7CTWFpbGZsb3d8eyJFbXB0eU1hcGkiOnRydWUsIlYiOiIwLjAuMDAwMCIsIlAiOiJXaW4zMiIsIkFOIjoiTWFpbCIsIldUIjoyfQ*3D*3D*7C0*7C*7C*7C&sdata=WJznJU*2FcU67Tws6YvzDP1ErhDly5gsfo3qS02BSEgYI*3D&reserved=0__;JSUlJSUlJSUlJSUlJSUlJSUlJSUlJSUl!!G_uCfscf7eWS!aWpmBWM1MgJ8DPElpy-lA2F39Xv8RBbhcGeURwxM7amRoqfGtKyFpqaRb0DuPM3p4S1O_EtkBZ7dpDuFuxxjF7s$ >
I don't understand why...I tried to remove the /Users/christophechalons/Library/Logs/Homebrew/moab directory but to no avail.
Thank you in advance for your help,
Christophe Chalons
