[MOAB-dev] [CELS WordPress Sites] Installation of Moab on MacOS 26.1
Mahadevan, Vijay S. mahadevan at anl.gov
Wed Dec 10 15:41:22 CST 2025
Hi Christophe,
Can you just clone the MOAB repository and build directly? The home-brew recipe seems outdated. For one, it is downloading MOAB 5.0.0 [1]. I think this needs to be updated. I am quite sure we did this in the past at some point, but I do not see the changes. I’ll submit a PR to update the recipe.
Meanwhile, if you can clone MOAB and build 5.6.0 tag, that should be quite stable. If you run into any issues, do let us know. You can also simply install MOAB through conda or spack, If those are convenient.
Best,
Vijay
[1] MOAB recipe: https://urldefense.us/v3/__https://github.com/brewsci/homebrew-science/blob/f3e9fae6ce2a3e0424291e9486deb0b82e5faa7b/Formula/moab.rb*L4__;Iw!!G_uCfscf7eWS!ZB0Uj2_RdtTHMEnjNkjhEoDOOO6LefCkZuj2mIenECjR50HlfQaGr5XnH3KEiifdJaP0Wpa0olcPu_ylhm-M0-M$ <https://urldefense.us/v3/__https://gcc02.safelinks.protection.outlook.com/?url=https*3A*2F*2Fgithub.com*2Fbrewsci*2Fhomebrew-science*2Fblob*2Ff3e9fae6ce2a3e0424291e9486deb0b82e5faa7b*2FFormula*2Fmoab.rb*23L4&data=05*7C02*7Cmoab-dev*40mcs.anl.gov*7C771b3459742c4809f6dd08de3834e5ef*7C0cfca18525f749e38ae7704d5326e285*7C0*7C0*7C639009997009838338*7CUnknown*7CTWFpbGZsb3d8eyJFbXB0eU1hcGkiOnRydWUsIlYiOiIwLjAuMDAwMCIsIlAiOiJXaW4zMiIsIkFOIjoiTWFpbCIsIldUIjoyfQ*3D*3D*7C0*7C*7C*7C&sdata=ElsRnB7cZ3bMtFieVzD5PAXmK*2B33wq2*2B89mFSsTUlM8*3D&reserved=0__;JSUlJSUlJSUlJSUlJSUlJSUlJSUlJSUlJSUlJSU!!G_uCfscf7eWS!ZB0Uj2_RdtTHMEnjNkjhEoDOOO6LefCkZuj2mIenECjR50HlfQaGr5XnH3KEiifdJaP0Wpa0olcPu_ylWzGtU_k$ >
From: Christophe-Alexandre Chalons-Mouriesse <christophealexandrechalons at gmail.com>
Date: Monday, December 8, 2025 at 12:37
To: Mahadevan, Vijay S. <mahadevan at anl.gov>
Cc: moab-dev at mcs.anl.gov <moab-dev at mcs.anl.gov>
Subject: Re: [CELS WordPress Sites] Installation of Moab on MacOS 26.1
You don't often get email from christophealexandrechalons at gmail.com. Learn why this is important<https://urldefense.us/v3/__https://aka.ms/LearnAboutSenderIdentification__;!!G_uCfscf7eWS!ZB0Uj2_RdtTHMEnjNkjhEoDOOO6LefCkZuj2mIenECjR50HlfQaGr5XnH3KEiifdJaP0Wpa0olcPu_yl0PJlR6I$ >
This Message Is From an External Sender
This message came from outside your organization.
Dear Vijay,
You will find attached the files that you requested plus the make file. It looks like it is failing during the make install.
==> make install
Last 15 lines from /Users/christophechalons/Library/Logs/Homebrew/moab/03.make.log:
../moab/Range.hpp:282:16: error: unknown type name 'EntityHandle'
  282 |   inline const EntityHandle& back() const;
../moab/Range.hpp:284:3: error: unknown type name 'EntityHandle'
  284 |   EntityHandle pop_front();
../moab/Range.hpp:286:3: error: unknown type name 'EntityHandle'
  286 |   EntityHandle pop_back();
fatal error: too many errors emitted, stopping now [-ferror-limit=]
20 errors generated.
make[3]: *** [ReadNASTRAN.lo] Error 1
make[2]: *** [install-recursive] Error 1
make[1]: *** [install-recursive] Error 1
make: *** [install-recursive] Error 1
I have uninstalled my homebrew and reinstalled it to be sure then I have updated and upgraded...
==> Updating Homebrew...
Already up-to-date.
Christophes-MacBook-Pro:Homebrew christophechalons$ brew upgrade
Christophe
Le lun. 8 déc. 2025 à 16:18, Mahadevan, Vijay S. <mahadevan at anl.gov<mailto:mahadevan at anl.gov>> a écrit :
Dear Christophe,
I don’t quite understand the error below. The link is perhaps garbled. Did your autoreconf command fail? Can you verify that your home-brew is up to date? Please do send the autoreconf.log file so that we can take a closer look.
Also, you should not be using 5.0.0. That version is probably a decade old! Please update to 5.6.0.
Best,
Vijay
From: Christophe Chalons <christophealexandrechalons at gmail.com<mailto:christophealexandrechalons at gmail.com>>
Date: Monday, December 8, 2025 at 09:02
To: Mahadevan, Vijay S. <mahadevan at anl.gov<mailto:mahadevan at anl.gov>>
Subject: [CELS WordPress Sites] Installation of Moab on MacOS 26.1
[You don't often get email from christophealexandrechalons at gmail.com<mailto:christophealexandrechalons at gmail.com>. Learn why this is important at https://urldefense.us/v3/__https://aka.ms/LearnAboutSenderIdentification__;!!G_uCfscf7eWS!ZB0Uj2_RdtTHMEnjNkjhEoDOOO6LefCkZuj2mIenECjR50HlfQaGr5XnH3KEiifdJaP0Wpa0olcPu_yl0PJlR6I$ <https://urldefense.us/v3/__https://gcc02.safelinks.protection.outlook.com/?url=https*3A*2F*2Furldefense.us*2Fv3*2F__https*3A*2F*2Faka.ms*2FLearnAboutSenderIdentification__*3B!!G_uCfscf7eWS!d28Hs5OvqWmJ_MC-_8cby9FNTNX9KxrhjrbAdgQ0mfXDYj1gf-JfM0cKjnDoysvxTqydQ7Dq8Uz-xTOSFPSFINRI_08*24&data=05*7C02*7Cmoab-dev*40mcs.anl.gov*7C771b3459742c4809f6dd08de3834e5ef*7C0cfca18525f749e38ae7704d5326e285*7C0*7C0*7C639009997009864763*7CUnknown*7CTWFpbGZsb3d8eyJFbXB0eU1hcGkiOnRydWUsIlYiOiIwLjAuMDAwMCIsIlAiOiJXaW4zMiIsIkFOIjoiTWFpbCIsIldUIjoyfQ*3D*3D*7C0*7C*7C*7C&sdata=7iQIuFz2UvF3IxXE6sXJGUlMMb*2FEyg4xFwCS0vANHHA*3D&reserved=0__;JSUlJSUlJSUlJSUlJSUlJSUlJSUlJSUlJSUlJSU!!G_uCfscf7eWS!ZB0Uj2_RdtTHMEnjNkjhEoDOOO6LefCkZuj2mIenECjR50HlfQaGr5XnH3KEiifdJaP0Wpa0olcPu_ylJ_QqKxM$ > ]
Hello,
When I try the command 'brew install moab' I have the following issue :
Christophes-MacBook-Pro:Homebrew christophechalons$ brew install moab
==> Fetching downloads for: moab
✔︎ Formula moab (5.0.0)        [Verifying    11.9MB/ 11.9MB]
==> Installing moab from brewsci/science
==> autoreconf -fi
Last 15 lines from /Users/christophechalons/Library/Logs/Homebrew/moab/01.autoreconf.log:
2025-12-08 13:53:52 +0000
autoreconf
-fi
If reporting this issue please do so at (not Homebrew/* repositories):
  https://urldefense.us/v3/__https://gcc02.safelinks.protection.outlook.com/?url=https*3A*2F*2Fgithub.com*2Fbrewsci*2Fhomebrew-science*2Fissues&data=05*7C02*7Cmahadevan*40anl.gov*7C46294d742ff849242c5208de36625ff0*7C0cfca18525f749e38ae7704d5326e285*7C0*7C0*7C639007993298704390*7CUnknown*7CTWFpbGZsb3d8eyJFbXB0eU1hcGkiOnRydWUsIlYiOiIwLjAuMDAwMCIsIlAiOiJXaW4zMiIsIkFOIjoiTWFpbCIsIldUIjoyfQ*3D*3D*7C80000*7C*7C*7C&sdata=mlg6B1pE8EqTkXHjg34pgaENA*2B8b48*2Bl6jQf1IQuH7E*3D&reserved=0__;JSUlJSUlJSUlJSUlJSUlJSUlJSUlJSUlJQ!!G_uCfscf7eWS!ZB0Uj2_RdtTHMEnjNkjhEoDOOO6LefCkZuj2mIenECjR50HlfQaGr5XnH3KEiifdJaP0Wpa0olcPu_yli6jgn3I$ <https://urldefense.us/v3/__https://gcc02.safelinks.protection.outlook.com/?url=https*3A*2F*2Furldefense.us*2Fv3*2F__https*3A*2F*2Fgithub.com*2Fbrewsci*2Fhomebrew-science*2Fissues__*3B!!G_uCfscf7eWS!d28Hs5OvqWmJ_MC-_8cby9FNTNX9KxrhjrbAdgQ0mfXDYj1gf-JfM0cKjnDoysvxTqydQ7Dq8Uz-xTOSFPSFFlGWfW8*24&data=05*7C02*7Cmoab-dev*40mcs.anl.gov*7C771b3459742c4809f6dd08de3834e5ef*7C0cfca18525f749e38ae7704d5326e285*7C0*7C0*7C639009997009882122*7CUnknown*7CTWFpbGZsb3d8eyJFbXB0eU1hcGkiOnRydWUsIlYiOiIwLjAuMDAwMCIsIlAiOiJXaW4zMiIsIkFOIjoiTWFpbCIsIldUIjoyfQ*3D*3D*7C0*7C*7C*7C&sdata=puZnVLf4j*2B2A3KTJte8i68Sh7J8wDbe2*2BneyKuH2G0k*3D&reserved=0__;JSUlJSUlJSUlJSUlJSUlJSUlJSUlJSUlJSUlJSUlJSU!!G_uCfscf7eWS!ZB0Uj2_RdtTHMEnjNkjhEoDOOO6LefCkZuj2mIenECjR50HlfQaGr5XnH3KEiifdJaP0Wpa0olcPu_ylqYnErv4$ >
I don't understand why...I tried to remove the /Users/christophechalons/Library/Logs/Homebrew/moab directory but to no avail.
Thank you in advance for your help,
Christophe Chalons
