[MOAB-dev] PyMOAB
Paul Wilson
paul.wilson at wisc.edu
Thu Sep 23 13:15:41 CDT 2021
Hi there,
Can you share how you built MOAB? either the 'configure' line or the
'cmake' line?
Paul
On 9/23/21 13:13, Kevin McLaughlin wrote:
> Hello,
> I'm trying to use MOAB for some neutronics work, but I am running into a problem relating to PyMOAB. I built MOAB, and everything seems to be functioning, but I am unable to setup PyMOAB. PyMOAB isn't importable in python, and there is only a setup.py.in file, not a setup.py file. When I try to run setup.py.in, I get the error "No such file or directory: '@abs_builddir@/pymoab'". I'm sure this is some mistake on my part, but I can't figure this out. Could you advise on how I can get PyMOAB set up?
> Thank you!
> Kevin McLaughlin
> office: 858-455-3641
> mclaughlink at fusion.gat.com
Paul P.H. Wilson (he/him/his)
Grainger Professor of Nuclear Engineering
Chair, Department of Engineering Physics <http://engr.wisc.edu/ep>
o: 608-263-0807, c: 608-469-9615
153 Engineering Research Bldg
1500 Engineering Dr, Madison, WI 53706
Zoom Meeting Room: https://uwmadison.zoom.us/j/6082630807
Zoom Phone Access: +1-929-205-6099, Access code: 6082630807
Computational Nuclear Engineering Research Group
<http://cnerg.engr.wisc.edu>
