[MOAB-dev] PyMOAB
    Kevin McLaughlin
    mclaughlink at fusion.gat.com
    Thu Sep 23 13:22:10 CDT 2021
Hi Paul,
Sure, I did
$ ../src/configure --enable-optimize \
                   --enable-shared \
                   --disable-debug \
                   --with-hdf5=/usr/lib/x86_64-linux-gnu/hdf5/serial \
                   --prefix=$HOME/dagmc_bld/MOAB \
                   --download-netcdf
Thanks!
Kevin McLaughlin
office: 858-455-3641
----- Original Message -----
To: "Kevin McLaughlin" <mclaughlink at fusion.gat.com>, "moab-dev" <moab-dev at mcs.anl.gov>
Sent: Thursday, September 23, 2021 11:15:41 AM
Subject: Re: [MOAB-dev] PyMOAB
Hi there,
Can you share how you built MOAB? either the 'configure' line or the
'cmake' line?
Paul
On 9/23/21 13:13, Kevin McLaughlin wrote:
> Hello,
> I'm trying to use MOAB for some neutronics work, but I am running into a problem relating to PyMOAB. I built MOAB, and everything seems to be functioning, but I am unable to setup PyMOAB. PyMOAB isn't importable in python, and there is only a setup.py.in file, not a setup.py file. When I try to run setup.py.in, I get the error "No such file or directory: '@abs_builddir@/pymoab'". I'm sure this is some mistake on my part, but I can't figure this out. Could you advise on how I can get PyMOAB set up?
> Thank you!
> Kevin McLaughlin
Paul P.H. Wilson (he/him/his)
Grainger Professor of Nuclear Engineering
Chair, Department of Engineering Physics <http://engr.wisc.edu/ep>
o: 608-263-0807, c: 608-469-9615
paul.wilson at wisc.edu
153 Engineering Research Bldg
1500 Engineering Dr, Madison, WI 53706
Zoom Meeting Room: https://uwmadison.zoom.us/j/6082630807
Zoom Phone Access: +1-929-205-6099, Access code: 6082630807
Computational Nuclear Engineering Research Group
<http://cnerg.engr.wisc.edu>
