[MOAB-dev] MOAB 4.6.3 error
Vijay S. Mahadevan
vijay.m at gmail.com
Tue Apr 27 18:43:31 CDT 2021
Hi Vikram,
I do not see the config files attached. Also, MOAB 4.6.3 is at least 4-5
years old. Can you upgrade to 5.2.0? It will be much easier to diagnose
issues.
Meanwhile, I'll check if the mailing list filtered out your attachments.
Vijay
On Tue., Apr. 27, 2021, 18:07 Bhamidipati, Vikram, <
vikram.bhamidipati at swri.org> wrote:
> Hello,
> I am trying to build MOAB 4.6.3 on CentOS with GCC 7.3. I used the
> following configure command:
> ./configure
> --prefix=/home/vbhamidipati/Documents/SciFEn/ScIFEN_source/externalpackages/build
> --libdir=/home/vbhamidipati/Documents/SciFEn/ScIFEN_source/externalpackages/build/lib
> CC=/usr/lib64/mpich-3.2/bin/mpicc CXX=/usr/lib64/mpich-3.2/bin/mpicxx
> F90=/usr/lib64/mpich-3.2/bin/mpifort F77=/usr/lib64/mpich-3.2/bin/mpifort
> FC=/usr/lib64/mpich-3.2/bin/mpifort --enable-static --enable-optimize
> --with-mpi
> --with-hdf5=/home/vbhamidipati/Documents/SciFEn/ScIFEN_source/externalpackages/build
> --with-parmetis=/home/vbhamidipati/Documents/SciFEn/ScIFEN_source/externalpackages/build
> --without-netcdf
> Both mpicc and mpicxx are configured to use GCC 7.3. I get build error(s).
> Build log file and error file (from redirecting stdout and stderr) are
> attached. Any help/insights will be appreciated.
> Thank you,
> Vikram
> Vikram Bhamidipati
> Senior Research Engineer
> Computational Material Integrity Section
> Materials Engineering Department
> Mechanical Engineering Division
> Ph: (210) 522-2576
