[MOAB-dev] MOAB 4.6.3 error
Bhamidipati, Vikram vikram.bhamidipati at swri.org
Tue Apr 27 20:20:49 CDT 2021
Thanks Vijay. Changing to 5.2.0 helped. I don’t get those errors any more. I am reattaching the earlier error file (with *.txt extension) in case there is any interest about the errors.
Vikram
Sent: Tuesday, April 27, 2021 6:44 PM
To: Bhamidipati, Vikram <vikram.bhamidipati at swri.org>
Cc: moab-dev at mcs.anl.gov
Subject: Re: [MOAB-dev] MOAB 4.6.3 error
[EXTERNAL EMAIL]
Hi Vikram,
I do not see the config files attached. Also, MOAB 4.6.3 is at least 4-5 years old. Can you upgrade to 5.2.0? It will be much easier to diagnose issues.
Meanwhile, I'll check if the mailing list filtered out your attachments.
Vijay
On Tue., Apr. 27, 2021, 18:07 Bhamidipati, Vikram, <vikram.bhamidipati at swri.org<mailto:vikram.bhamidipati at swri.org>> wrote:
Hello,
I am trying to build MOAB 4.6.3 on CentOS with GCC 7.3. I used the following configure command:
./configure --prefix=/home/vbhamidipati/Documents/SciFEn/ScIFEN_source/externalpackages/build --libdir=/home/vbhamidipati/Documents/SciFEn/ScIFEN_source/externalpackages/build/lib CC=/usr/lib64/mpich-3.2/bin/mpicc CXX=/usr/lib64/mpich-3.2/bin/mpicxx F90=/usr/lib64/mpich-3.2/bin/mpifort F77=/usr/lib64/mpich-3.2/bin/mpifort FC=/usr/lib64/mpich-3.2/bin/mpifort --enable-static --enable-optimize --with-mpi --with-hdf5=/home/vbhamidipati/Documents/SciFEn/ScIFEN_source/externalpackages/build --with-parmetis=/home/vbhamidipati/Documents/SciFEn/ScIFEN_source/externalpackages/build --without-netcdf
Both mpicc and mpicxx are configured to use GCC 7.3. I get build error(s). Build log file and error file (from redirecting stdout and stderr) are attached. Any help/insights will be appreciated.
Thank you,
Vikram
Vikram Bhamidipati
Senior Research Engineer
Computational Material Integrity Section
Materials Engineering Department
Mechanical Engineering Division
Ph: (210) 522-2576
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20210428/172c5e75/attachment-0001.txt>
