[MOAB-dev] MOAB 4.6.3 error
Bhamidipati, Vikram vikram.bhamidipati at swri.org
Tue Apr 27 17:06:54 CDT 2021
Hello,
I am trying to build MOAB 4.6.3 on CentOS with GCC 7.3. I used the following configure command:
./configure --prefix=/home/vbhamidipati/Documents/SciFEn/ScIFEN_source/externalpackages/build --libdir=/home/vbhamidipati/Documents/SciFEn/ScIFEN_source/externalpackages/build/lib CC=/usr/lib64/mpich-3.2/bin/mpicc CXX=/usr/lib64/mpich-3.2/bin/mpicxx F90=/usr/lib64/mpich-3.2/bin/mpifort F77=/usr/lib64/mpich-3.2/bin/mpifort FC=/usr/lib64/mpich-3.2/bin/mpifort --enable-static --enable-optimize --with-mpi --with-hdf5=/home/vbhamidipati/Documents/SciFEn/ScIFEN_source/externalpackages/build --with-parmetis=/home/vbhamidipati/Documents/SciFEn/ScIFEN_source/externalpackages/build --without-netcdf
Both mpicc and mpicxx are configured to use GCC 7.3. I get build error(s). Build log file and error file (from redirecting stdout and stderr) are attached. Any help/insights will be appreciated.
Thank you,
Vikram
Vikram Bhamidipati
Senior Research Engineer
Computational Material Integrity Section
Materials Engineering Department
Mechanical Engineering Division
Ph: (210) 522-2576
