[MOAB-dev] Polygon->polyhedra adjacencies bug?
Timothy Tautges ttautges at simscale.com
Tue Aug 25 16:21:27 CDT 2020
Yes, that's the one that probably rings a bell. The one I'm looking at now
looks different; the faces are conformal, and the polyhedron knows about
the polygon, but the polygon doesn't appear to know about the polyhedra. If
you haven't seen anything similar, then I'll work on isolating it in a
simple test program. I'll ask here if I can send you the mesh.
- tim
On Tue, Aug 25, 2020 at 4:15 PM Vijay S. Mahadevan <vijay.m at gmail.com>
wrote:
> Hi Tim,
> I think you may be referring to the bug that Johannes Probst raised here
> [1].
> I am not sure whether this is a logical or a design issue since the
> behavior charted out appears to be what I would have expected, but
> clearly not what Johannes wanted.
> Did you have a different discussion in mind ?
> Vijay
> [1]
> https://bitbucket.org/fathomteam/moab/issues/117/incorrect-adjacencies-in-polyhedral-mesh
> On Tue, Aug 25, 2020 at 5:02 PM Timothy Tautges <ttautges at simscale.com>
> wrote:
> > Hi all, I've run across a bug, where a polygon doesn't know about its
> > adjacent polyhedra. But, something rings a bell about that being a known
> > bug that got discussed during the last few months. Does that ring a bell
> > with anybody here?
> > Thanks.
> > - tim
