[MOAB-dev] Moab and C++17
John R Cary cary at txcorp.com
Tue Oct 22 10:55:45 CDT 2019
Thanks, Paul.  We do have Moab ported to Windows and working, so we could
set a PR, but first we have to sync-up, and there are lots of conflicts.
So before we start on this, we would prefer that all other work on Windows
ports be in so that we do not duplicate effort.  Would this be possible
in a modest amount of time?
In response to Vijay -- we build our toolchain on multiple platforms
(Windows VS, Windows LLVM, macOS same, Linux various compilers) using
Jenkins as the driver and our own Bilder as a package manager for building
and running tests.
To make sure I understand, we should branch off master -- after you get
current PRs in.  Then add our code.  Then submit a pull request to your
develop.  Is this right?
Thx.....John
On 10/22/19 11:27 AM, Paul Wilson wrote:
> Hi John,
> There have been a few attempts at a Windows port - or partial windows
> ports - that live in branches and/or PRs.  I'm most familiar with this
> one: https://bitbucket.org/fathomteam/moab/pull-requests/405 that
> Baptiste worked on.
> Paul
> On 10/22/19 10:11, John R Cary via moab-dev wrote:
>> Thanks, Vijay.
>> On a related note, we had started porting Moab to Windows. When merging
>> our changes to your develop branch, we found a number of conflicts.
>> Did you port Moab to Windows?
>> And you still want pull requests to your develop branch?
>> Thx.....John
>> On 10/22/19 10:24 AM, Vijay S. Mahadevan wrote:
>>> John,
>>> AFAIK, no one has verified this. If you already have some checks,
>>> please let us know and we will try to fix incompatibility. Or if you
>>> can submit changes as PRs, thst would be much appreciated.
>>> I do want to note that MOAB is C++03 compliant still and we only
>>> recently started adding new dependencies that have C++11 requirements.
>>> Thanks,
>>> Vijay
>>> On Tue., Oct. 22, 2019, 8:58 a.m. John R Cary via moab-dev,
>>> <moab-dev at mcs.anl.gov <mailto:moab-dev at mcs.anl.gov>> wrote:
>>>     We have recently ported most of our build chain to c++17.
>>>     However, our fork of moab is not c++-17 compliant.  Is the
>>>     main repo c++17 compliant?
>>>     Thx....John Cary
> Paul P.H. Wilson (he/him/his)
> Grainger Professor of Nuclear Engineering
> Chair, Department of Engineering Physics <http://engr.wisc.edu/ep>
> Chair, Energy Analysis and Policy Certificate <http://eap.wisc.edu>
> 608-263-0807
> paul.wilson at wisc.edu
> 153 Engineering Research Bldg
> 1500 Engineering Dr, Madison, WI 53706
> Computational Nuclear Engineering Research Group
> <http://cnerg.engr.wisc.edu>
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20191022/4575a3be/attachment.html>
