[MOAB-dev] Moab and C++17
Paul Wilson paul.wilson at wisc.edu
Tue Oct 22 10:27:33 CDT 2019
Hi John,
There have been a few attempts at a Windows port - or partial windows ports - that live in branches and/or PRs.  I'm most familiar with this one: https://bitbucket.org/fathomteam/moab/pull-requests/405 that Baptiste worked on.
Paul
On 10/22/19 10:11, John R Cary via moab-dev wrote:
Thanks, Vijay.
On a related note, we had started porting Moab to Windows.  When merging
our changes to your develop branch, we found a number of conflicts.
Did you port Moab to Windows?
And you still want pull requests to your develop branch?
Thx.....John
On 10/22/19 10:24 AM, Vijay S. Mahadevan wrote:
John,
AFAIK, no one has verified this. If you already have some checks, please let us know and we will try to fix incompatibility. Or if you can submit changes as PRs, thst would be much appreciated.
I do want to note that MOAB is C++03 compliant still and we only recently started adding new dependencies that have C++11 requirements.
Vijay
On Tue., Oct. 22, 2019, 8:58 a.m. John R Cary via moab-dev, <moab-dev at mcs.anl.gov<mailto:moab-dev at mcs.anl.gov>> wrote:
We have recently ported most of our build chain to c++17.
However, our fork of moab is not c++-17 compliant.  Is the
main repo c++17 compliant?
Thx....John Cary
Paul P.H. Wilson (he/him/his)
Grainger Professor of Nuclear Engineering
Chair, Department of Engineering Physics<http://engr.wisc.edu/ep>
Chair, Energy Analysis and Policy Certificate<http://eap.wisc.edu>
608-263-0807
paul.wilson at wisc.edu<mailto:paul.wilson at wisc.edu>
153 Engineering Research Bldg
1500 Engineering Dr, Madison, WI 53706
Computational Nuclear Engineering Research Group<http://cnerg.engr.wisc.edu>
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20191022/c07e23c1/attachment.html>
