[MOAB-dev] Failed to rebuild obb trees!
Lukasz Kaczmarczyk Lukasz.Kaczmarczyk at glasgow.ac.uk
Fri Apr 19 14:36:37 CDT 2019
On 19 Apr 2019, at 14:26, Paul Wilson via moab-dev <moab-dev at mcs.anl.gov<mailto:moab-dev at mcs.anl.gov>> wrote:
Hello Lukasz,
We may need to revisit some of the logic of the Cub file reader.  These errors imply that MOAB is attempting to process a geometry representation in addition to the mesh representation.
Prior to more testing, I can't tell if this is because:
a) Your options don't request that the geometry representation be loaded from the file, but MOAB tries to process the geometry anyway, or
b) The geometry representation is being loaded (although I think your choice of options should be preventing that), and the presence of sheet bodies in your model is causing the geometry processing to fail.
I'll see if I can get someone to confirm which of these situations it is (or perhaps something else) so that we can determine how to resolve it.
Paul
Paul,
You right, this error appears for a newer version of moab. Does not appear when the mesh is generated by other meshers than a cubit. Thanks for looking at this. It does not affect how the code works but results in an error warning printed on the screen.
One option will be to prevent moab to guess geometry representation when the option is given while loading the mesh. Or switch it off for cubit file types.
Kind regards,
Lukasz
On 4/19/19 06:02, Lukasz Kaczmarczyk via moab-dev wrote:
Hello,
I have a strange problem with the reading file test_mesh_cut.cub. Mesh is ok, I can process it. The issue is with the error.
Code:
    const char *option;
    option = "";
    moab.load_file(mesh_file_name, 0, option);
Is this problem with the file or something related to a cubit. The problem appears for v5.1, for older versions seems to be ok.
Lukasz
129: [0]MOAB ERROR: --------------------- Error Message ------------------------------------
129: [0]MOAB ERROR: Failed to join the obb trees!
129: [0]MOAB ERROR: construct_obb_tree() line 502 in src/GeomTopoTool.cpp
129: [0]MOAB ERROR: Failed to construct obb tree for volume!
129: [0]MOAB ERROR: construct_obb_trees() line 606 in src/GeomTopoTool.cpp
129: [0]MOAB ERROR: Error: Failed to rebuild obb trees!
129: [0]MOAB ERROR: GeomTopoTool() line 90 in src/GeomTopoTool.cpp
129: [0]MOAB ERROR: get_senses() line 1075 in src/GeomTopoTool.cpp
129: [0]MOAB ERROR: get_data() line 277 in src/DenseTag.cpp
Paul P.H. Wilson (he/him/his)
Grainger Professor of Nuclear Engineering
608-263-0807
paul.wilson at wisc.edu<mailto:paul.wilson at wisc.edu>
443 Engineering Research Bldg
1500 Engineering Dr, Madison, WI 53706
My Calendar<https://outlook.office365.com/owa/calendar/09741ed238d644298e6c66dc97afedd4@wisc.edu/5df8b1d04e964755a5811e89a908217a313307426944667793/calendar.html>
Computational Nuclear Engineering Research Group<http://cnerg.engr.wisc.edu/>
Energy Analysis and Policy Program<http://eap.wisc.edu/>
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20190419/fa58593a/attachment.html>
