[MOAB-dev] Failed to rebuild obb trees!
Paul Wilson
paul.wilson at wisc.edu
Fri Apr 19 08:26:29 CDT 2019
Hello Lukasz,
We may need to revisit some of the logic of the Cub file reader. These errors imply that MOAB is attempting to process a geometry representation in addition to the mesh representation.
Prior to more testing, I can't tell if this is because:
a) Your options don't request that the geometry representation be loaded from the file, but MOAB tries to process the geometry anyway, or
b) The geometry representation is being loaded (although I think your choice of options should be preventing that), and the presence of sheet bodies in your model is causing the geometry processing to fail.
I'll see if I can get someone to confirm which of these situations it is (or perhaps something else) so that we can determine how to resolve it.
Paul
On 4/19/19 06:02, Lukasz Kaczmarczyk via moab-dev wrote:
Hello,
I have a strange problem with the reading file test_mesh_cut.cub. Mesh is ok, I can process it. The issue is with the error.
Code:
const char *option;
option = "";
moab.load_file(mesh_file_name, 0, option);
Is this problem with the file or something related to a cubit. The problem appears for v5.1, for older versions seems to be ok.
Lukasz
129: [0]MOAB ERROR: --------------------- Error Message ------------------------------------
129: [0]MOAB ERROR: Failed to join the obb trees!
129: [0]MOAB ERROR: construct_obb_tree() line 502 in src/GeomTopoTool.cpp
129: [0]MOAB ERROR: Failed to construct obb tree for volume!
129: [0]MOAB ERROR: construct_obb_trees() line 606 in src/GeomTopoTool.cpp
129: [0]MOAB ERROR: Error: Failed to rebuild obb trees!
129: [0]MOAB ERROR: GeomTopoTool() line 90 in src/GeomTopoTool.cpp
129: [0]MOAB ERROR: get_senses() line 1075 in src/GeomTopoTool.cpp
129: [0]MOAB ERROR: get_data() line 277 in src/DenseTag.cpp
Paul P.H. Wilson (he/him/his)
Grainger Professor of Nuclear Engineering
608-263-0807
paul.wilson at wisc.edu<mailto:paul.wilson at wisc.edu>
443 Engineering Research Bldg
1500 Engineering Dr, Madison, WI 53706
My Calendar<https://outlook.office365.com/owa/calendar/09741ed238d644298e6c66dc97afedd4@wisc.edu/5df8b1d04e964755a5811e89a908217a313307426944667793/calendar.html>
Computational Nuclear Engineering Research Group<http://cnerg.engr.wisc.edu>
Energy Analysis and Policy Program<http://eap.wisc.edu>
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20190419/243abd70/attachment.html>
