[MOAB-dev] Failed to rebuild obb trees!
Lukasz Kaczmarczyk Lukasz.Kaczmarczyk at glasgow.ac.uk
Fri Apr 19 06:02:21 CDT 2019
Hello,
I have a strange problem with the reading file test_mesh_cut.cub. Mesh is ok, I can process it. The issue is with the error.
Code:
    const char *option;
    option = "";
    moab.load_file(mesh_file_name, 0, option);
Is this problem with the file or something related to a cubit. The problem appears for v5.1, for older versions seems to be ok.
Lukasz
129: [0]MOAB ERROR: --------------------- Error Message ------------------------------------
129: [0]MOAB ERROR: Failed to join the obb trees!
129: [0]MOAB ERROR: construct_obb_tree() line 502 in src/GeomTopoTool.cpp
129: [0]MOAB ERROR: Failed to construct obb tree for volume!
129: [0]MOAB ERROR: construct_obb_trees() line 606 in src/GeomTopoTool.cpp
129: [0]MOAB ERROR: Error: Failed to rebuild obb trees!
129: [0]MOAB ERROR: GeomTopoTool() line 90 in src/GeomTopoTool.cpp
129: [0]MOAB ERROR: get_senses() line 1075 in src/GeomTopoTool.cpp
129: [0]MOAB ERROR: get_data() line 277 in src/DenseTag.cpp
Desc: test_mesh_cut.cub
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20190419/3b22c4fb/attachment-0001.obj>
