[MOAB-dev] Removing HO nodes from entities
Lukasz Kaczmarczyk
Lukasz.Kaczmarczyk at glasgow.ac.uk
Thu Mar 29 10:36:49 CDT 2018
Thanks Vijay,
My colleague encountered this problem.
If you remove ho-nodes, you have to remove them first from edges, then faces at the end of volumes. Then it works.
I will send a link to the code once he pushes it to the repo.
Kind regards,
Lukasz
> On 29 Mar 2018, at 16:30, Vijay S. Mahadevan <vijay.m at gmail.com> wrote:
> Hello Lukasz,
> Sorry about the late reply. Yes convert_entities is supposed to help
> with this. Do you have a simple test to replicate the issue you are
> seeing ? I'll check the implementation to see if there is any cases
> that are not handled correctly. Our FTP site is down and so online
> documentation may not be available at this time.
> Vijay
> On Wed, Mar 28, 2018 at 6:10 AM, Lukasz Kaczmarczyk
> <Lukasz.Kaczmarczyk at glasgow.ac.uk> wrote:
>> Hello,
>> Can you advise how to remove HO nodes from entities? I hope that I could do that using convert_entities, but is not working.
>> Kind regards,
>> Lukasz
>> [University of Glasgow: The Times Scottish University of the Year 2018]
