[MOAB-dev] Removing HO nodes from entities
Vijay S. Mahadevan vijay.m at gmail.com
Thu Mar 29 10:55:09 CDT 2018
Thanks. A patch or a PR would be much appreciated.
Vijay
On Thu, Mar 29, 2018 at 11:36 AM, Lukasz Kaczmarczyk
<Lukasz.Kaczmarczyk at glasgow.ac.uk> wrote:
> Thanks Vijay,
> My colleague encountered this problem.
> If you remove ho-nodes, you have to remove them first from edges, then faces at the end of volumes.  Then it works.
> I will send a link to the code once he pushes it to the repo.
> Kind regards,
> Lukasz
>> On 29 Mar 2018, at 16:30, Vijay S. Mahadevan <vijay.m at gmail.com> wrote:
>> Hello Lukasz,
>> Sorry about the late reply. Yes convert_entities is supposed to help
>> with this. Do you have a simple test to replicate the issue you are
>> seeing ? I'll check the implementation to see if there is any cases
>> that are not handled correctly. Our FTP site is down and so online
>> documentation may not be available at this time.
>> Vijay
>> On Wed, Mar 28, 2018 at 6:10 AM, Lukasz Kaczmarczyk
>>> Hello,
>>> Can you advise how to remove HO nodes from entities? I hope that I could do that using convert_entities, but is not working.
>>> Kind regards,
>>> Lukasz
>>> [University of Glasgow: The Times Scottish University of the Year 2018]
