[MOAB-dev] MOAB build error with irel enabled.
Vijay S. Mahadevan
vijay.m at gmail.com
Wed May 24 08:05:27 CDT 2017
Sorry about our delayed reply.
We are still fixing the CMake configuration for MeshKit. I should be able
to push the changes later today. As of now, I don't think the CMake builds
work out of the box for MeshKit. CGM/MOAB CMake builds are much more stable
however.
Note: You should be using the "master" branch in both CGM and MOAB if you
want CMake builds. These changes will be part of the upcoming release.
Vijay
On Tue, May 23, 2017 at 5:41 PM, Madhusudhan Kundrapu <madhusnk at txcorp.com>
wrote:
> Hello,
> I am seeing the following moab-config errors while building MeshKit on Mac
> OS.
> 1. For both ser and par configs:
> CMake Error at itaps/CMakeLists.txt:18 (add_subdirectory):
> The source directory
> ..../moab/itaps/irel
> does not contain a CMakeLists.txt file.
> Q: Does irel originally has a CMakeLists file?
> 2. For the ser config:
> -- Found CGM: /opt/utest/volatile-clangcxx11/cgm-stable.r1597-sersh/
> include/cgm
> -- Checking whether Fortran compiler has -isysroot
> -- Checking whether Fortran compiler has -isysroot - yes
> -- Checking whether Fortran compiler supports OSX deployment target flag
> -- Checking whether Fortran compiler supports OSX deployment target flag -
> yes
> -- Detecting Fortran/C Interface
> -- Detecting Fortran/C Interface - Found GLOBAL but not MODULE mangling
> CMake Error: The following variables are used in this project, but they
> are set to NOTFOUND.
> Please set them or make sure they are set and tested correctly in the
> CMake files:
> MPI_EXTRA_LIBRARY
> linked by target "MOAB" in directory ..../moab/src
> Could you please help me on fixing the above config errors.
> Thanks,
> Madhu
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20170524/e78a8623/attachment.html>
