[MOAB-dev] MOAB build error with irel enabled.
Madhusudhan Kundrapu madhusnk at txcorp.com
Wed May 24 08:11:15 CDT 2017
Thanks Vijay,
Madhu
On 05/24/2017 07:05 AM, Vijay S. Mahadevan wrote:
> Sorry about our delayed reply.
> We are still fixing the CMake configuration for MeshKit. I should be
> able to push the changes later today. As of now, I don't think the
> CMake builds work out of the box for MeshKit. CGM/MOAB CMake builds
> are much more stable however.
> Note: You should be using the "master" branch in both CGM and MOAB if
> you want CMake builds. These changes will be part of the upcoming release.
> Vijay
> On Tue, May 23, 2017 at 5:41 PM, Madhusudhan Kundrapu
> <madhusnk at txcorp.com <mailto:madhusnk at txcorp.com>> wrote:
>     Hello,
>     I am seeing the following moab-config errors while building
>     MeshKit on Mac OS.
>     1. For both ser and par configs:
>     CMake Error at itaps/CMakeLists.txt:18 (add_subdirectory):
>       The source directory
>     ..../moab/itaps/irel
>       does not contain a CMakeLists.txt file.
>     Q: Does irel originally has a CMakeLists file?
>     2. For the ser config:
>     -- Found CGM:
>     /opt/utest/volatile-clangcxx11/cgm-stable.r1597-sersh/include/cgm
>     -- Checking whether Fortran compiler has -isysroot
>     -- Checking whether Fortran compiler has -isysroot - yes
>     -- Checking whether Fortran compiler supports OSX deployment
>     target flag
>     target flag - yes
>     -- Detecting Fortran/C Interface
>     -- Detecting Fortran/C Interface - Found GLOBAL but not MODULE
>     mangling
>     CMake Error: The following variables are used in this project, but
>     they are set to NOTFOUND.
>     Please set them or make sure they are set and tested correctly in
>     the CMake files:
>     MPI_EXTRA_LIBRARY
>         linked by target "MOAB" in directory ..../moab/src
>     Could you please help me on fixing the above config errors.
>     Thanks,
>     Madhu
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20170524/ac323196/attachment.html>
