[MOAB-dev] MOABconfig.h
    Vijay S. Mahadevan
    vijay.m at gmail.com
    Sun Aug 21 12:30:22 CDT 2016
Andy, yes I see that MOABConfig.h is now not installed. This is my
bad. I was trying to make sure MOABConfig.h is not part of the
distribution but my change affected the installations also. Thanks for
verifying this.
Also, Version.h is removed because all the defines are now available
in MOABConfig.h. If there is a need for the original Version.h still,
please let me know why.
I'll push a fix to master soon. Thanks,
Vijay
On Sat, Aug 20, 2016 at 7:13 PM, Andrew Davis <andrew.davis at wisc.edu> wrote:
> Also to be clear, Version.h has gone?
> On Sat, Aug 20, 2016 at 7:10 PM, Andrew Davis <andrew.davis at wisc.edu> wrote:
>> Iulian
>> We use Version.h, it just turns out our ifdef we incorrect so it wasn't
>> being used properly. I'll write a test and pop it on in.
>> So on our Docker based Ubuntu 14.04 build I consistently see this behavior
>> where moab/MOABConfig.h is not correctly installed. It appears to be made,
>> but not installed with make install. I've also built it on two different
>> linux machines with the same result. It seems make install does not install
>> the header into the include directory?
>> Thanks
>> Andy
>> Thanks
>> Andy
>> On Fri, Aug 19, 2016 at 4:38 PM, Grindeanu, Iulian R. <iulian at mcs.anl.gov>
>> wrote:
>>> MOABConfig.h should not be part of tar file, it was removed from
>>> distribution. It should not be part of distribution. This change is part of
>>> vijaysm/fix-dist (pull request #254)
>>> I don't know anything that uses moab/Version.h
>>> MOABConfig.h is built when you configure, not when you autoreconf -fi
>>> Iulian
>>> ________________________________
>>> From: moab-dev-bounces at mcs.anl.gov [moab-dev-bounces at mcs.anl.gov] on
>>> behalf of Andrew Davis [andrew.davis at wisc.edu]
>>> Sent: Friday, August 19, 2016 4:17 PM
>>> To: moab-dev at mcs.anl.gov
>>> Subject: [MOAB-dev] MOABconfig.h
>>> Hi Folks
>>> Has MOABconfig.h been removed in the master branch? My autotools based
>>> build seems to not have it any more? Also, does anyone know if there are any
>>> tests that rely on moab/Version.h, I've only just noticed but it seems that
>>> for my builds it doesn't actually do anything?
>>> Thanks
>>> Andy
