[MOAB-dev] MOABconfig.h
    Andrew Davis
    andrew.davis at wisc.edu
    Sat Aug 20 19:13:03 CDT 2016
Also to be clear, Version.h has gone?
On Sat, Aug 20, 2016 at 7:10 PM, Andrew Davis <andrew.davis at wisc.edu> wrote:
> Iulian
> We use Version.h, it just turns out our ifdef we incorrect so it wasn't
> being used properly. I'll write a test and pop it on in.
> So on our Docker based Ubuntu 14.04 build I consistently see this
> behavior where moab/MOABConfig.h is not correctly installed. It appears to
> be made, but not installed with make install. I've also built it on two
> different linux machines with the same result. It seems make install does
> not install the header into the include directory?
> Thanks
> Andy
> Thanks
> Andy
> On Fri, Aug 19, 2016 at 4:38 PM, Grindeanu, Iulian R. <iulian at mcs.anl.gov>
> wrote:
>> MOABConfig.h should not be part of tar file, it was removed from
>> distribution. It should not be part of distribution. This change is part of
>> vijaysm/fix-dist (pull request #254)
>> I don't know anything that uses moab/Version.h
>> MOABConfig.h is built when you configure, not when you autoreconf -fi
>> Iulian
>> *From:* moab-dev-bounces at mcs.anl.gov [moab-dev-bounces at mcs.anl.gov] on
>> behalf of Andrew Davis [andrew.davis at wisc.edu]
>> *Sent:* Friday, August 19, 2016 4:17 PM
>> *To:* moab-dev at mcs.anl.gov
>> *Subject:* [MOAB-dev] MOABconfig.h
>> Hi Folks
>> Has MOABconfig.h been removed in the master branch? My autotools based
>> build seems to not have it any more? Also, does anyone know if there are
>> any tests that rely on moab/Version.h, I've only just noticed but it seems
>> that for my builds it doesn't actually do anything?
>> Thanks
>> Andy
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20160820/040a03bd/attachment.html>
