[MOAB-dev] MOABconfig.h
    Andrew Davis
    andrew.davis at wisc.edu
    Sat Aug 20 19:10:00 CDT 2016
Iulian
We use Version.h, it just turns out our ifdef we incorrect so it wasn't
being used properly. I'll write a test and pop it on in.
So on our Docker based Ubuntu 14.04 build I consistently see this behavior
where moab/MOABConfig.h is not correctly installed. It appears to be made,
but not installed with make install. I've also built it on two different
linux machines with the same result. It seems make install does not install
the header into the include directory?
Thanks
Andy
Thanks
Andy
On Fri, Aug 19, 2016 at 4:38 PM, Grindeanu, Iulian R. <iulian at mcs.anl.gov>
wrote:
> MOABConfig.h should not be part of tar file, it was removed from
> distribution. It should not be part of distribution. This change is part of
> vijaysm/fix-dist (pull request #254)
> I don't know anything that uses moab/Version.h
> MOABConfig.h is built when you configure, not when you autoreconf -fi
> Iulian
> *From:* moab-dev-bounces at mcs.anl.gov [moab-dev-bounces at mcs.anl.gov] on
> behalf of Andrew Davis [andrew.davis at wisc.edu]
> *Sent:* Friday, August 19, 2016 4:17 PM
> *To:* moab-dev at mcs.anl.gov
> *Subject:* [MOAB-dev] MOABconfig.h
> Hi Folks
> Has MOABconfig.h been removed in the master branch? My autotools based
> build seems to not have it any more? Also, does anyone know if there are
> any tests that rely on moab/Version.h, I've only just noticed but it seems
> that for my builds it doesn't actually do anything?
> Thanks
> Andy
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20160820/bf2dcecd/attachment.html>
