[MOAB-dev] MOABconfig.h
    Grindeanu, Iulian R.
    iulian at mcs.anl.gov
    Fri Aug 19 16:38:50 CDT 2016
MOABConfig.h should not be part of tar file, it was removed from distribution. It should not be part of distribution. This change is part of vijaysm/fix-dist (pull request #254)
I don't know anything that uses moab/Version.h
MOABConfig.h is built when you configure, not when you autoreconf -fi
Iulian
From: moab-dev-bounces at mcs.anl.gov [moab-dev-bounces at mcs.anl.gov] on behalf of Andrew Davis [andrew.davis at wisc.edu]
Sent: Friday, August 19, 2016 4:17 PM
To: moab-dev at mcs.anl.gov
Subject: [MOAB-dev] MOABconfig.h
Hi Folks
Has MOABconfig.h been removed in the master branch? My autotools based build seems to not have it any more? Also, does anyone know if there are any tests that rely on moab/Version.h, I've only just noticed but it seems that for my builds it doesn't actually do anything?
Thanks
Andy
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20160819/fc4ab73a/attachment.html>
