[MOAB-dev] Error message when compiling the mbcoupler_test.cpp
    Jie Wu
    jie.voo at gmail.com
    Fri May 13 18:12:56 CDT 2016
Hi Iulian,
Make clean for folders moab src and test works! Now all the tests have passed! Thank you so much for your help!
Best,
Jie
> On May 13, 2016, at 6:16 PM, Grindeanu, Iulian R. <iulian at mcs.anl.gov> wrote:
> Another possible cause is that you do not have a clean build.
> can you do a make clean in your moab src and test folder, and then make and make check again. (this assumes that your configuration was successful already, as you reported)
> I cannot explain why your MPI calls would have problems
> From: Jie Wu [jie.voo at gmail.com]
> Sent: Friday, May 13, 2016 3:41 PM
> To: Vijay S. Mahadevan
> Cc: Grindeanu, Iulian R.; moab-dev at mcs.anl.gov
> Subject: Re: [MOAB-dev] Error message when compiling the mbcoupler_test.cpp
> Hi Vijay,
> Thank you so much for your help! 'Make install’ works good on my laptop.
> I am looking forward to seeing the possible causes of the failing tests.
> Best,
> Jie
>> On May 13, 2016, at 4:08 PM, Vijay S. Mahadevan <vijay.m at gmail.com> wrote:
>> Ok, looks like your MPI installation and MOAB+MPI are configured and
>> working fine. We will look at the tests and see why they are failing.
>> I haven't been able to replicate the errors locally but I think we
>> should be able to find the issue soon.
>> If "make install" works (you should configure with a
>> --prefix=$INSTALL_DIR option), you can start using the library now.
>> I'll update you once we find the root cause for the issues you found.
>> Vijay
>> On Fri, May 13, 2016 at 2:12 PM, Jie Wu <jie.voo at gmail.com> wrote:
>>> Hi there,
>>> Thank you for your directions! Here is the results I get after issuing make
>>> -k check at directory test/parallel, and I think they look good.
>>> dyn-160-39-10-173:parallel jiewu$ make -k check
>>> /Applications/Xcode.app/Contents/Developer/usr/bin/make  pcomm_unit scdtest
>>> pcomm_serial par_spatial_locator_test parallel_unit_tests scdpart
>>> read_nc_par ucdtrvpart mpastrvpart gcrm_par   parallel_hdf5_test
>>> mhdf_parallel parallel_write_test uber_parallel_test parallel_adj
>>> parmerge_test augment_with_ghosts  imeshp_test mbparallelcomm_test partcheck
>>> structured3 parmerge
>>> CXX      pcomm_unit.o
>>> CXXLD    pcomm_unit
>>> CXX      scdtest.o
>>> CXXLD    scdtest
>>> CXX      pcomm_serial.o
>>> CXXLD    pcomm_serial
>>> CXX      par_spatial_locator_test.o
>>> CXXLD    par_spatial_locator_test
>>> CXX      parallel_unit_tests.o
>>> CXXLD    parallel_unit_tests
>>> CXX      scdpart.o
>>> CXXLD    scdpart
>>> CXX      ../io/read_nc.o
>>> CXXLD    read_nc_par
>>> CXX      ucdtrvpart.o
>>> CXXLD    ucdtrvpart
>>> CXX      mpastrvpart.o
>>> CXXLD    mpastrvpart
>>> CXX      gcrm_par.o
>>> CXXLD    gcrm_par
>>> CXX      parallel_hdf5_test.o
>>> CXXLD    parallel_hdf5_test
>>> CC       mhdf_parallel.o
>>> CCLD     mhdf_parallel
>>> CXX      parallel_write_test.o
>>> CXXLD    parallel_write_test
>>> CXX      uber_parallel_test.o
>>> CXXLD    uber_parallel_test
>>> CXX      ../adj_moab_test.o
>>> CXXLD    parallel_adj
>>> CXX      parmerge_test.o
>>> CXXLD    parmerge_test
>>> CXX      augment_with_ghosts.o
>>> CXXLD    augment_with_ghosts
>>> PPFC     imeshp_test.o
>>> FCLD     imeshp_test
>>> CXX      mbparallelcomm_test.o
>>> CXXLD    mbparallelcomm_test
>>> CXX      partcheck.o
>>> CXXLD    partcheck
>>> CXX      structured3.o
>>> CXXLD    structured3
>>> CXX      parmerge.o
>>> CXXLD    parmerge
>>> /Applications/Xcode.app/Contents/Developer/usr/bin/make  check-TESTS
>>> PASS: pcomm_unit
>>> PASS: scdtest
>>> PASS: pcomm_serial
>>> PASS: par_spatial_locator_test
>>> PASS: parallel_unit_tests
>>> PASS: scdpart
>>> PASS: read_nc_par
>>> PASS: ucdtrvpart
>>> PASS: mpastrvpart
>>> PASS: gcrm_par
>>> PASS: parallel_hdf5_test
>>> PASS: mhdf_parallel
>>> PASS: parallel_write_test
>>> PASS: uber_parallel_test
>>> PASS: parallel_adj
>>> PASS: parmerge_test
>>> PASS: augment_with_ghosts
>>> PASS: imeshp_test
>>> Testsuite summary for MOAB 4.9.2pre
>>> # TOTAL: 18
>>> # PASS:  18
>>> # SKIP:  0
>>> # XFAIL: 0
>>> # FAIL:  0
>>> # XPASS: 0
>>> # ERROR: 0
>>> Following is an example I run with mpiexec, and I think it also goes well.
>>> Thank you very much for your help! Any help deal with the failing tests will
>>> be much appreciated.
>>> Best,
>>> Jie
>>> dyn-160-39-10-173:mbcoupler jiewu$ mpiexec -np 2  mbcoupler_test -meshes
>>> /Users/wujie/SourceCode/moab/MeshFiles/unittest/64bricks_1khex.h5m
>>> /Users/wujie/SourceCode/moab/MeshFiles/unittest/64bricks_12ktet.h5m -itag
>>> vertex_field -outfile dum.h5m
>>> ReadHDF5:             0.0324039
>>> get set meta        0.00103188
>>> partial subsets     0.000803947
>>> partition time      2.14577e-06
>>> get set ids         0.000556946
>>> set contents        0.00107098
>>> polyhedra           2.5034e-05
>>> elements            0.00174189
>>> nodes               0.0014832
>>> node adjacency      0
>>> side elements       0.000672817
>>> update connectivity 0.000102043
>>> adjacency           0
>>> delete non_adj      0.00338697
>>> recursive sets      0
>>> find contain_sets   0.000369072
>>> read sets           0.00147104
>>> read tags           0.01667
>>> store file ids      0.00191593
>>> read qa records     0.000133038
>>> Parallel Read times:
>>> 0.0473361 PARALLEL READ PART
>>> 0.0138111 PARALLEL RESOLVE_SHARED_ENTS
>>> 0.0113361 PARALLEL EXCHANGE_GHOSTS
>>> 0.00113177 PARALLEL RESOLVE_SHARED_SETS
>>> 0.00648403 PARALLEL_AUGMENT_SETS_WITH_GHOSTS
>>> 0.079994 PARALLEL TOTAL
>>> ReadHDF5:             0.0714378
>>> get set meta        0.000261784
>>> partial subsets     0.000660181
>>> partition time      9.53674e-07
>>> get set ids         0.00101304
>>> set contents        0.000728846
>>> polyhedra           0.000128031
>>> elements            0.0155201
>>> nodes               0.00354886
>>> node adjacency      6.19888e-06
>>> side elements       0.00422001
>>> update connectivity 0.00184798
>>> adjacency           0
>>> delete non_adj      0.0100739
>>> recursive sets      0
>>> find contain_sets   0.00218511
>>> read sets           0.00258899
>>> read tags           0.0235598
>>> store file ids      0.0044961
>>> read qa records     9.5129e-05
>>> 0.0779119 PARALLEL READ PART
>>> 0.0667319 PARALLEL RESOLVE_SHARED_ENTS
>>> 0.0397439 PARALLEL EXCHANGE_GHOSTS
>>> 0.00435901 PARALLEL RESOLVE_SHARED_SETS
>>> 0.0243261 PARALLEL_AUGMENT_SETS_WITH_GHOSTS
>>> 0.209468 PARALLEL TOTAL
>>> Proc 1 iface entities:
>>>   446 0d iface entities.
>>>   1080 1d iface entities.
>>>   Proc 0636 2d iface entities.
>>>   0 3d iface entities.
>>> iface entities:
>>>   108   (446 verts adj to other iface ents)
>>> rank 0 points of interest: 6155
>>> rank 1 points of interest: 6155
>>> Max time : 0.101124 0.0461781 0.00104499 (inst loc interp -- 2 procs)
>>> WriteHDF5:           0.0779669
>>> gather mesh:       0.00237203
>>> create file:       0.0655501
>>>   create nodes:    0.00201201
>>>   negotiate types: 2.19345e-05
>>>   create elem:     0.000785828
>>>   file id exch:    0.0234561
>>>   create adj:      0.000414848
>>>   create set:      0.019654
>>>     shared ids:    6.19888e-05
>>>     shared data:   0.014715
>>>     set offsets:   0.00447798
>>>   create tags:     0.0160849
>>> coordinates:       0.00199103
>>> connectivity:      0.00162005
>>> sets:              0.0010829
>>>   set descrip:     0.00019598
>>>   set content:     0.000527859
>>>   set parent:      0.000226021
>>>   set child:       0.000128984
>>> adjacencies:       5.96046e-06
>>> tags:              0.00700402
>>>   dense data:      0.00127792
>>>   sparse data:     0.00569224
>>>   var-len data:    0
>>> Wrote dum.h5m
>>> mbcoupler_test complete.
>>> On May 13, 2016, at 2:58 PM, Grindeanu, Iulian R. <iulian at mcs.anl.gov>
>>> wrote:
>>> yes, can you try make -k check  ?
>>> It will not stop at the first failed test, it will try to test everything
>>> From: Vijay S. Mahadevan [vijay.m at gmail.com]
>>> Sent: Friday, May 13, 2016 1:53 PM
>>> To: Jie Wu
>>> Jie,
>>> We are looking into the failing tests and will update in case there is
>>> a bug in the code. Our nightly tests are running cleanly and so I'm
>>> curious to see if other tests are failing. Can you go to test/parallel
>>> and run "make check" there to verify if the parallel job launch is
>>> working correctly ? Also, can you verify if you can run MPI programs
>>> with mpiexec ?
>>> Vijay
>>> Vijay
>>> On Fri, May 13, 2016 at 1:31 PM, Jie Wu <jie.voo at gmail.com> wrote:
>>> Hi Vijay,
>>> Deleting the auto-installed packages under sandbox before issue new
>>> configurations works good! No error message emerged until I input the
>>> command make check, which is as following.
>>> Do you have any idea for this problem?
>>> Best,
>>> Jie
>>> PASS: reorder_test
>>> FAIL: test_prog_opt
>>> PASS: coords_connect_iterate
>>> PASS: elem_eval_test
>>> PASS: spatial_locator_test
>>> PASS: test_boundbox
>>> PASS: adj_moab_test
>>> PASS: uref_mesh_test
>>> PASS: verdict_test
>>> PASS: test_Matrix3
>>> PASS: mbfacet_test
>>> PASS: gttool_test
>>> PASS: cropvol_test
>>> FAIL: mergemesh_test
>>> PASS: mbground_test
>>> PASS: lloyd_smoother_test
>>> # TOTAL: 36
>>> # PASS:  34
>>> # SKIP:  0
>>> # XFAIL: 0
>>> # FAIL:  2
>>> # XPASS: 0
>>> # ERROR: 0
>>> See test/test-suite.log
>>> Please report to moab-dev at mcs.anl.gov
>>> make[4]: *** [test-suite.log] Error 1
>>> make[3]: *** [check-TESTS] Error 2
>>> make[2]: *** [check-am] Error 2
>>> make[1]: *** [check-recursive] Error 1
>>> make: *** [check-recursive] Error 1
>>> On May 13, 2016, at 1:08 PM, Vijay S. Mahadevan <vijay.m at gmail.com> wrote:
>>> Jie, since you now changed the compilers used to configure the stack,
>>> I would advise deleting the auto-installed packages under sandbox
>>> directory and then re-configuring. This will force the rebuild of
>>> HDF5/NetCDF packages with the parallel MPI compilers and you should
>>> get the HDF5-parallel support enabled after that. Makes sense ?
>>> Vijay
>>> On Fri, May 13, 2016 at 11:27 AM, Jie Wu <jie.voo at gmail.com> wrote:
>>> Hi Vijay,
>>> Thank you for your reply. The new configuration do works. Here shows the
>>> command I inputed and the message while I input: make check.
>>> dyn-160-39-10-173:moab jiewu$ ./configure --with-mpi=/usr/local
>>> CC=/usr/local/bin/mpicc CXX=/usr/local/bin/mpic++ FC=/usr/local/bin/mpif90
>>> F77=/usr/local/bin/mpif77 --download-metis --download-hdf5 --download-netcdf
>>> --enable-docs --with-doxygen=/Applications/Doxygen.app/Contents/Resources/
>>> The results are
>>> configure: WARNING:
>>> *        MOAB has been configured with parallel and HDF5 support
>>> *     but the configured HDF5 library does not support parallel IO.
>>> *            Some parallel IO capabilities will be disabled.
>>> After that, I inputted the command, make -j4, and then command make check.
>>> Here are the results it shows
>>> PASS: elem_util_test
>>> PASS: element_test
>>> FAIL: datacoupler_test
>>> FAIL: mbcoupler_test
>>> FAIL: parcoupler_test
>>> # TOTAL: 5
>>> # PASS:  2
>>> # SKIP:  0
>>> # XFAIL: 0
>>> # FAIL:  3
>>> # XPASS: 0
>>> # ERROR: 0
>>> See tools/mbcoupler/test-suite.log
>>> Then I was trying to run the mbcouple_test with command
>>> Now the results look like,
>>> [0]MOAB ERROR: --------------------- Error Message
>>> [0]MOAB ERROR: MOAB not configured with parallel HDF5 support!
>>> [0]MOAB ERROR: set_up_read() line 355 in src/io/ReadHDF5.cpp
>>> [0]MOAB ERROR: NULL file handle.!
>>> [0]MOAB ERROR: is_error() line 133 in src/io/ReadHDF5.hpp
>>> [1]MOAB ERROR: --------------------- Error Message
>>> [1]MOAB ERROR: MOAB not configured with parallel HDF5 support!
>>> [1]MOAB ERROR: set_up_read() line 355 in src/io/ReadHDF5.cpp
>>> [1]MOAB ERROR: NULL file handle.!
>>> [1]MOAB ERROR: is_error() line 133 in src/io/ReadHDF5.hpp
>>> [0]MOAB ERROR: Failed to load file after trying all possible readers!
>>> [0]MOAB ERROR: serial_load_file() line 635 in src/Core.cpp
>>> [0]MOAB ERROR: Failed in step PARALLEL READ PART!
>>> [0]MOAB ERROR: load_file() line 553 in src/parallel/ReadParallel.cpp
>>> [0]MOAB ERROR: load_file() line 252 in src/parallel/ReadParallel.cpp
>>> [0]MOAB ERROR: load_file() line 515 in src/Core.cpp
>>> [1]MOAB ERROR: Failed to load file after trying all possible readers!
>>> [1]MOAB ERROR: serial_load_file() line 635 in src/Core.cpp
>>> [1]MOAB ERROR: Failed in step PARALLEL READ PART!
>>> [1]MOAB ERROR: load_file() line 553 in src/parallel/ReadParallel.cpp
>>> [0]MOAB ERROR: main() line 172 in mbcoupler_test.cpp
>>> [1]MOAB ERROR: load_file() line 252 in src/parallel/ReadParallel.cpp
>>> [1]MOAB ERROR: load_file() line 515 in src/Core.cpp
>>> [1]MOAB ERROR: main() line 172 in mbcoupler_test.cpp
>>> MPI_ABORT was invoked on rank 0 in communicator MPI_COMM_WORLD
>>> with errorcode 16.
>>> NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
>>> You may or may not see output from other processes, depending on
>>> exactly when Open MPI kills them.
>>> [dyn-160-39-11-172.dyn.columbia.edu:26361] 1 more process has sent help
>>> message help-mpi-api.txt / mpi-abort
>>> [dyn-160-39-11-172.dyn.columbia.edu:26361] Set MCA parameter
>>> "orte_base_help_aggregate" to 0 to see all help / error messages
>>> The other excitable file in mbcoupler folder, like ./element_test now can
>>> run successfully.
>>> Any direction for this was deeply appreciated!
>>> Best,
>>> Jie
>>> On May 13, 2016, at 11:54 AM, Vijay S. Mahadevan <vijay.m at gmail.com> wrote:
>>> I also forgot to mention that you can be more explicit in the
>>> specification of compilers during configuration, if you really want.
>>> This would avoid headaches since the user specified wrappers will
>>> directly be used. For example:
>>> ./configure --with-mpi=/usr/local CC=/usr/local/bin/mpicc
>>> F77=/usr/local/bin/mpif77 <OTHER_CONFIGURE_OPTIONS>
>>> Vijay
>>> On Fri, May 13, 2016 at 10:52 AM, Vijay S. Mahadevan <vijay.m at gmail.com>
>>> wrote:
>>> Please use --with-mpi=/usr/local as the configure option. If you have
>>> MPI pre-installed, either through PETSc or natively in your system,
>>> always try to re-use that to maintain consistency. This will help
>>> avoid mix-up of MPI implementations when you try to launch a parallel
>>> job later.
>>> Let us know if the new configuration works.
>>> Vijay
>>> On Thu, May 12, 2016 at 6:32 PM, Jie Wu <jie.voo at gmail.com> wrote:
>>> Thank you very much for your reply. I search in my src/moab/MOABConfig.h
>>> file, and I did not find the MOAB_HAVE_MPI. So I think the MOAB on my laptop
>>> cannot run in parallel yet.
>>> I have this from my terminal.
>>> dyn-160-39-10-173:moab jiewu$ which mpic++
>>> But I cannot get anything by inputing which mpi. So I don’t know where the
>>> mpi is in my laptop.
>>> I have petsc installed which has mpich, and linking that directory to the
>>> MOAB configure option also did not work.
>>> Should I install mpi solely? I am afraid it might conflict with the one
>>> installed in petsc.
>>> Is there any method that the mpi could be installed with MOAB automatically,
>>> or maybe other proper manner? Thanks a lot!
>>> Best,
>>> Jie
>>> On May 12, 2016, at 6:11 PM, Vijay S. Mahadevan <vijay.m at gmail.com> wrote:
>>> Can you send the config.log. Looks like MPI is not getting enabled
>>> (possibly), even with --dowload-mpich. Or you can check
>>> src/moab/MOABConfig.h in your build directory and grep for
>>> MOAB_HAVE_MPI.
>>> Vijay
>>> On Thu, May 12, 2016 at 4:46 PM, Jie Wu <jie.voo at gmail.com> wrote:
>>> Hi Iulian,
>>> Thanks for your reply. I think my configure is with mpi. Here is my
>>> configure command
>>> dyn-160-39-10-173:moab jiewu$    ./configure --download-metis
>>> --download-hdf5 --download-netcdf --download-mpich --enable-docs
>>> Best,
>>> Jie
>>> On May 12, 2016, at 5:43 PM, Grindeanu, Iulian R. <iulian at mcs.anl.gov>
>>> wrote:
>>> Hi Jie,
>>> Did you configure with mpi? What is your configure command?
>>> Iulian
>>> From: moab-dev-bounces at mcs.anl.gov [moab-dev-bounces at mcs.anl.gov] on behalf
>>> of Jie Wu [jie.voo at gmail.com]
>>> Sent: Thursday, May 12, 2016 4:23 PM
>>> To: moab-dev at mcs.anl.gov
>>> Subject: [MOAB-dev] Error message when compiling the mbcoupler_test.cpp
>>> Hi all,
>>> My name is Jie and I am part of computational mechanics group at civil
>>> engineering dept. of Columbia university.
>>> I am working on large deformation problems which may lead mesh distortions
>>> and a re-meshing become necessary.
>>> I would like to compile mbcoupler_test.cpp to learn how it transfer the
>>> variables from old to the new mesh.
>>> Now I can successfully compile the codes in build/examples and they works
>>> good! But I cannot compile the codes in folder build/tools/mbcoupler by
>>> following the instructions in build/tools/readme.tools, which shows error
>>> message like following.
>>> Do you have any idea for this problem? Thanks a lot!
>>> Best,
>>> Jie
>>> DataCoupler.cpp:136:25: error: member access into incomplete
>>> type 'moab::ParallelComm'
>>> if (myPcomm && myPcomm->size() > 1) {
>>> ./DataCoupler.hpp:34:7: note: forward declaration of
>>> class ParallelComm;
>>> DataCoupler.cpp:161:12: error: member access into incomplete
>>> myPcomm->proc_config().crystal_router()->gs_tran...
>>> class ParallelComm;
>>> DataCoupler.cpp:187:12: error: member access into incomplete
>>> class ParallelComm;
>>> 3 errors generated.
>>> make[2]: *** [DataCoupler.lo] Error 1
>>> make[2]: *** Waiting for unfinished jobs....
>>> Coupler.cpp:344:45: error: no member named 'gs_transfer' in
>>> 'moab::gs_data::crystal_data'
>>> (myPc->proc_config().crystal_router())->gs_trans...
>>> Coupler.cpp:388:45: error: no member named 'gs_transfer' in
>>> Coupler.cpp:611:45: error: no member named 'gs_transfer' in
>>> Coupler.cpp:638:43: error: no member named 'gs_transfer' in
>>> myPc->proc_config().crystal_router()->gs_transfe...
>>> 4 errors generated.
>>> make[2]: *** [Coupler.lo] Error 1
>>> make[1]: *** [all-recursive] Error 1
>>> make: *** [all-recursive] Error 1
