[MOAB-dev] Error message when compiling the mbcoupler_test.cpp
Grindeanu, Iulian R. iulian at mcs.anl.gov
Fri May 13 17:16:48 CDT 2016
Another possible cause is that you do not have a clean build.
can you do a make clean in your moab src and test folder, and then make and make check again. (this assumes that your configuration was successful already, as you reported)
I cannot explain why your MPI calls would have problems
Sent: Friday, May 13, 2016 3:41 PM
To: Vijay S. Mahadevan
Cc: Grindeanu, Iulian R.; moab-dev at mcs.anl.gov
Subject: Re: [MOAB-dev] Error message when compiling the mbcoupler_test.cpp
Hi Vijay,
Thank you so much for your help! 'Make install’ works good on my laptop.
I am looking forward to seeing the possible causes of the failing tests.
Best,
Jie
> On May 13, 2016, at 4:08 PM, Vijay S. Mahadevan <vijay.m at gmail.com> wrote:
> Ok, looks like your MPI installation and MOAB+MPI are configured and
> working fine. We will look at the tests and see why they are failing.
> I haven't been able to replicate the errors locally but I think we
> should be able to find the issue soon.
> If "make install" works (you should configure with a
> --prefix=$INSTALL_DIR option), you can start using the library now.
> I'll update you once we find the root cause for the issues you found.
> Vijay
> On Fri, May 13, 2016 at 2:12 PM, Jie Wu <jie.voo at gmail.com> wrote:
>> Hi there,
>> Thank you for your directions! Here is the results I get after issuing make
>> -k check at directory test/parallel, and I think they look good.
>> dyn-160-39-10-173:parallel jiewu$ make -k check
>> /Applications/Xcode.app/Contents/Developer/usr/bin/make  pcomm_unit scdtest
>> pcomm_serial par_spatial_locator_test parallel_unit_tests scdpart
>> read_nc_par ucdtrvpart mpastrvpart gcrm_par   parallel_hdf5_test
>> mhdf_parallel parallel_write_test uber_parallel_test parallel_adj
>> parmerge_test augment_with_ghosts  imeshp_test mbparallelcomm_test partcheck
>> structured3 parmerge
>>  CXX      pcomm_unit.o
>>  CXXLD    pcomm_unit
>>  CXX      scdtest.o
>>  CXXLD    scdtest
>>  CXX      pcomm_serial.o
>>  CXXLD    pcomm_serial
>>  CXX      par_spatial_locator_test.o
>>  CXXLD    par_spatial_locator_test
>>  CXX      parallel_unit_tests.o
>>  CXXLD    parallel_unit_tests
>>  CXX      scdpart.o
>>  CXXLD    scdpart
>>  CXX      ../io/read_nc.o
>>  CXXLD    read_nc_par
>>  CXX      ucdtrvpart.o
>>  CXXLD    ucdtrvpart
>>  CXX      mpastrvpart.o
>>  CXXLD    mpastrvpart
>>  CXX      gcrm_par.o
>>  CXXLD    gcrm_par
>>  CXX      parallel_hdf5_test.o
>>  CXXLD    parallel_hdf5_test
>>  CC       mhdf_parallel.o
>>  CCLD     mhdf_parallel
>>  CXX      parallel_write_test.o
>>  CXXLD    parallel_write_test
>>  CXX      uber_parallel_test.o
>>  CXXLD    uber_parallel_test
>>  CXX      ../adj_moab_test.o
>>  CXXLD    parallel_adj
>>  CXX      parmerge_test.o
>>  CXXLD    parmerge_test
>>  CXX      augment_with_ghosts.o
>>  CXXLD    augment_with_ghosts
>>  PPFC     imeshp_test.o
>>  FCLD     imeshp_test
>>  CXX      mbparallelcomm_test.o
>>  CXXLD    mbparallelcomm_test
>>  CXX      partcheck.o
>>  CXXLD    partcheck
>>  CXX      structured3.o
>>  CXXLD    structured3
>>  CXX      parmerge.o
>>  CXXLD    parmerge
>> /Applications/Xcode.app/Contents/Developer/usr/bin/make  check-TESTS
>> PASS: pcomm_unit
>> PASS: scdtest
>> PASS: pcomm_serial
>> PASS: par_spatial_locator_test
>> PASS: parallel_unit_tests
>> PASS: scdpart
>> PASS: read_nc_par
>> PASS: ucdtrvpart
>> PASS: mpastrvpart
>> PASS: gcrm_par
>> PASS: parallel_hdf5_test
>> PASS: mhdf_parallel
>> PASS: parallel_write_test
>> PASS: uber_parallel_test
>> PASS: parallel_adj
>> PASS: parmerge_test
>> PASS: augment_with_ghosts
>> PASS: imeshp_test
>> Testsuite summary for MOAB 4.9.2pre
>> # TOTAL: 18
>> # PASS:  18
>> # SKIP:  0
>> # XFAIL: 0
>> # FAIL:  0
>> # XPASS: 0
>> # ERROR: 0
>> Following is an example I run with mpiexec, and I think it also goes well.
>> Thank you very much for your help! Any help deal with the failing tests will
>> be much appreciated.
>> Best,
>> Jie
>> dyn-160-39-10-173:mbcoupler jiewu$ mpiexec -np 2  mbcoupler_test -meshes
>> /Users/wujie/SourceCode/moab/MeshFiles/unittest/64bricks_1khex.h5m
>> /Users/wujie/SourceCode/moab/MeshFiles/unittest/64bricks_12ktet.h5m -itag
>> vertex_field -outfile dum.h5m
>> ReadHDF5:             0.0324039
>>  get set meta        0.00103188
>>  partial subsets     0.000803947
>>  partition time      2.14577e-06
>>  get set ids         0.000556946
>>  set contents        0.00107098
>>  polyhedra           2.5034e-05
>>  elements            0.00174189
>>  nodes               0.0014832
>>  node adjacency      0
>>  side elements       0.000672817
>>  update connectivity 0.000102043
>>  adjacency           0
>>  delete non_adj      0.00338697
>>  recursive sets      0
>>  find contain_sets   0.000369072
>>  read sets           0.00147104
>>  read tags           0.01667
>>  store file ids      0.00191593
>>  read qa records     0.000133038
>> Parallel Read times:
>>  0.0473361 PARALLEL READ PART
>>  0.0138111 PARALLEL RESOLVE_SHARED_ENTS
>>  0.0113361 PARALLEL EXCHANGE_GHOSTS
>>  0.00113177 PARALLEL RESOLVE_SHARED_SETS
>>  0.00648403 PARALLEL_AUGMENT_SETS_WITH_GHOSTS
>>  0.079994 PARALLEL TOTAL
>> ReadHDF5:             0.0714378
>>  get set meta        0.000261784
>>  partial subsets     0.000660181
>>  partition time      9.53674e-07
>>  get set ids         0.00101304
>>  set contents        0.000728846
>>  polyhedra           0.000128031
>>  elements            0.0155201
>>  nodes               0.00354886
>>  node adjacency      6.19888e-06
>>  side elements       0.00422001
>>  update connectivity 0.00184798
>>  adjacency           0
>>  delete non_adj      0.0100739
>>  recursive sets      0
>>  find contain_sets   0.00218511
>>  read sets           0.00258899
>>  read tags           0.0235598
>>  store file ids      0.0044961
>>  read qa records     9.5129e-05
>>  0.0779119 PARALLEL READ PART
>>  0.0667319 PARALLEL RESOLVE_SHARED_ENTS
>>  0.0397439 PARALLEL EXCHANGE_GHOSTS
>>  0.00435901 PARALLEL RESOLVE_SHARED_SETS
>>  0.0243261 PARALLEL_AUGMENT_SETS_WITH_GHOSTS
>>  0.209468 PARALLEL TOTAL
>> Proc 1 iface entities:
>>    446 0d iface entities.
>>    1080 1d iface entities.
>>    Proc 0636 2d iface entities.
>>    0 3d iface entities.
>>  iface entities:
>>    108   (446 verts adj to other iface ents)
>> rank 0 points of interest: 6155
>> rank 1 points of interest: 6155
>> Max time : 0.101124 0.0461781 0.00104499 (inst loc interp -- 2 procs)
>> WriteHDF5:           0.0779669
>>  gather mesh:       0.00237203
>>  create file:       0.0655501
>>    create nodes:    0.00201201
>>    negotiate types: 2.19345e-05
>>    create elem:     0.000785828
>>    file id exch:    0.0234561
>>    create adj:      0.000414848
>>    create set:      0.019654
>>      shared ids:    6.19888e-05
>>      shared data:   0.014715
>>      set offsets:   0.00447798
>>    create tags:     0.0160849
>>  coordinates:       0.00199103
>>  connectivity:      0.00162005
>>  sets:              0.0010829
>>    set descrip:     0.00019598
>>    set content:     0.000527859
>>    set parent:      0.000226021
>>    set child:       0.000128984
>>  adjacencies:       5.96046e-06
>>  tags:              0.00700402
>>    dense data:      0.00127792
>>    sparse data:     0.00569224
>>    var-len data:    0
>> Wrote dum.h5m
>> mbcoupler_test complete.
>> On May 13, 2016, at 2:58 PM, Grindeanu, Iulian R. <iulian at mcs.anl.gov>
>> wrote:
>> yes, can you try make -k check  ?
>> It will not stop at the first failed test, it will try to test everything
>> From: Vijay S. Mahadevan [vijay.m at gmail.com]
>> Sent: Friday, May 13, 2016 1:53 PM
>> To: Jie Wu
>> Jie,
>> We are looking into the failing tests and will update in case there is
>> a bug in the code. Our nightly tests are running cleanly and so I'm
>> curious to see if other tests are failing. Can you go to test/parallel
>> and run "make check" there to verify if the parallel job launch is
>> working correctly ? Also, can you verify if you can run MPI programs
>> with mpiexec ?
>> Vijay
>> Vijay
>> On Fri, May 13, 2016 at 1:31 PM, Jie Wu <jie.voo at gmail.com> wrote:
>> Hi Vijay,
>> Deleting the auto-installed packages under sandbox before issue new
>> configurations works good! No error message emerged until I input the
>> command make check, which is as following.
>> Do you have any idea for this problem?
>> Best,
>> Jie
>> PASS: reorder_test
>> FAIL: test_prog_opt
>> PASS: coords_connect_iterate
>> PASS: elem_eval_test
>> PASS: spatial_locator_test
>> PASS: test_boundbox
>> PASS: adj_moab_test
>> PASS: uref_mesh_test
>> PASS: verdict_test
>> PASS: test_Matrix3
>> PASS: mbfacet_test
>> PASS: gttool_test
>> PASS: cropvol_test
>> FAIL: mergemesh_test
>> PASS: mbground_test
>> PASS: lloyd_smoother_test
>> # TOTAL: 36
>> # PASS:  34
>> # SKIP:  0
>> # XFAIL: 0
>> # FAIL:  2
>> # XPASS: 0
>> # ERROR: 0
>> See test/test-suite.log
>> Please report to moab-dev at mcs.anl.gov
>> make[4]: *** [test-suite.log] Error 1
>> make[3]: *** [check-TESTS] Error 2
>> make[2]: *** [check-am] Error 2
>> make[1]: *** [check-recursive] Error 1
>> make: *** [check-recursive] Error 1
>> On May 13, 2016, at 1:08 PM, Vijay S. Mahadevan <vijay.m at gmail.com> wrote:
>> Jie, since you now changed the compilers used to configure the stack,
>> I would advise deleting the auto-installed packages under sandbox
>> directory and then re-configuring. This will force the rebuild of
>> HDF5/NetCDF packages with the parallel MPI compilers and you should
>> get the HDF5-parallel support enabled after that. Makes sense ?
>> Vijay
>> On Fri, May 13, 2016 at 11:27 AM, Jie Wu <jie.voo at gmail.com> wrote:
>> Hi Vijay,
>> Thank you for your reply. The new configuration do works. Here shows the
>> command I inputed and the message while I input: make check.
>> dyn-160-39-10-173:moab jiewu$ ./configure --with-mpi=/usr/local
>> CC=/usr/local/bin/mpicc CXX=/usr/local/bin/mpic++ FC=/usr/local/bin/mpif90
>> F77=/usr/local/bin/mpif77 --download-metis --download-hdf5 --download-netcdf
>> --enable-docs --with-doxygen=/Applications/Doxygen.app/Contents/Resources/
>> The results are
>> configure: WARNING:
>> *        MOAB has been configured with parallel and HDF5 support
>> *     but the configured HDF5 library does not support parallel IO.
>> *            Some parallel IO capabilities will be disabled.
>> After that, I inputted the command, make -j4, and then command make check.
>> Here are the results it shows
>> PASS: elem_util_test
>> PASS: element_test
>> FAIL: datacoupler_test
>> FAIL: mbcoupler_test
>> FAIL: parcoupler_test
>> # TOTAL: 5
>> # PASS:  2
>> # SKIP:  0
>> # XFAIL: 0
>> # FAIL:  3
>> # XPASS: 0
>> # ERROR: 0
>> See tools/mbcoupler/test-suite.log
>> Then I was trying to run the mbcouple_test with command
>> Now the results look like,
>> [0]MOAB ERROR: --------------------- Error Message
>> [0]MOAB ERROR: MOAB not configured with parallel HDF5 support!
>> [0]MOAB ERROR: set_up_read() line 355 in src/io/ReadHDF5.cpp
>> [0]MOAB ERROR: NULL file handle.!
>> [0]MOAB ERROR: is_error() line 133 in src/io/ReadHDF5.hpp
>> [1]MOAB ERROR: --------------------- Error Message
>> [1]MOAB ERROR: MOAB not configured with parallel HDF5 support!
>> [1]MOAB ERROR: set_up_read() line 355 in src/io/ReadHDF5.cpp
>> [1]MOAB ERROR: NULL file handle.!
>> [1]MOAB ERROR: is_error() line 133 in src/io/ReadHDF5.hpp
>> [0]MOAB ERROR: Failed to load file after trying all possible readers!
>> [0]MOAB ERROR: serial_load_file() line 635 in src/Core.cpp
>> [0]MOAB ERROR: Failed in step PARALLEL READ PART!
>> [0]MOAB ERROR: load_file() line 553 in src/parallel/ReadParallel.cpp
>> [0]MOAB ERROR: load_file() line 252 in src/parallel/ReadParallel.cpp
>> [0]MOAB ERROR: load_file() line 515 in src/Core.cpp
>> [1]MOAB ERROR: Failed to load file after trying all possible readers!
>> [1]MOAB ERROR: serial_load_file() line 635 in src/Core.cpp
>> [1]MOAB ERROR: Failed in step PARALLEL READ PART!
>> [1]MOAB ERROR: load_file() line 553 in src/parallel/ReadParallel.cpp
>> [0]MOAB ERROR: main() line 172 in mbcoupler_test.cpp
>> [1]MOAB ERROR: load_file() line 252 in src/parallel/ReadParallel.cpp
>> [1]MOAB ERROR: load_file() line 515 in src/Core.cpp
>> [1]MOAB ERROR: main() line 172 in mbcoupler_test.cpp
>> MPI_ABORT was invoked on rank 0 in communicator MPI_COMM_WORLD
>> with errorcode 16.
>> NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
>> You may or may not see output from other processes, depending on
>> exactly when Open MPI kills them.
>> [dyn-160-39-11-172.dyn.columbia.edu:26361] 1 more process has sent help
>> message help-mpi-api.txt / mpi-abort
>> [dyn-160-39-11-172.dyn.columbia.edu:26361] Set MCA parameter
>> "orte_base_help_aggregate" to 0 to see all help / error messages
>> The other excitable file in mbcoupler folder, like ./element_test now can
>> run successfully.
>> Any direction for this was deeply appreciated!
>> Best,
>> Jie
>> On May 13, 2016, at 11:54 AM, Vijay S. Mahadevan <vijay.m at gmail.com> wrote:
>> I also forgot to mention that you can be more explicit in the
>> specification of compilers during configuration, if you really want.
>> This would avoid headaches since the user specified wrappers will
>> directly be used. For example:
>> ./configure --with-mpi=/usr/local CC=/usr/local/bin/mpicc
>> F77=/usr/local/bin/mpif77 <OTHER_CONFIGURE_OPTIONS>
>> Vijay
>> On Fri, May 13, 2016 at 10:52 AM, Vijay S. Mahadevan <vijay.m at gmail.com>
>> wrote:
>> Please use --with-mpi=/usr/local as the configure option. If you have
>> MPI pre-installed, either through PETSc or natively in your system,
>> always try to re-use that to maintain consistency. This will help
>> avoid mix-up of MPI implementations when you try to launch a parallel
>> job later.
>> Let us know if the new configuration works.
>> Vijay
>> On Thu, May 12, 2016 at 6:32 PM, Jie Wu <jie.voo at gmail.com> wrote:
>> Thank you very much for your reply. I search in my src/moab/MOABConfig.h
>> file, and I did not find the MOAB_HAVE_MPI. So I think the MOAB on my laptop
>> cannot run in parallel yet.
>> I have this from my terminal.
>> dyn-160-39-10-173:moab jiewu$ which mpic++
>> But I cannot get anything by inputing which mpi. So I don’t know where the
>> mpi is in my laptop.
>> I have petsc installed which has mpich, and linking that directory to the
>> MOAB configure option also did not work.
>> Should I install mpi solely? I am afraid it might conflict with the one
>> installed in petsc.
>> Is there any method that the mpi could be installed with MOAB automatically,
>> or maybe other proper manner? Thanks a lot!
>> Best,
>> Jie
>> On May 12, 2016, at 6:11 PM, Vijay S. Mahadevan <vijay.m at gmail.com> wrote:
>> Can you send the config.log. Looks like MPI is not getting enabled
>> (possibly), even with --dowload-mpich. Or you can check
>> src/moab/MOABConfig.h in your build directory and grep for
>> MOAB_HAVE_MPI.
>> Vijay
>> On Thu, May 12, 2016 at 4:46 PM, Jie Wu <jie.voo at gmail.com> wrote:
>> Hi Iulian,
>> Thanks for your reply. I think my configure is with mpi. Here is my
>> configure command
>> dyn-160-39-10-173:moab jiewu$    ./configure --download-metis
>> --download-hdf5 --download-netcdf --download-mpich --enable-docs
>> Best,
>> Jie
>> On May 12, 2016, at 5:43 PM, Grindeanu, Iulian R. <iulian at mcs.anl.gov>
>> wrote:
>> Hi Jie,
>> Did you configure with mpi? What is your configure command?
>> Iulian
>> From: moab-dev-bounces at mcs.anl.gov [moab-dev-bounces at mcs.anl.gov] on behalf
>> of Jie Wu [jie.voo at gmail.com]
>> Sent: Thursday, May 12, 2016 4:23 PM
>> To: moab-dev at mcs.anl.gov
>> Subject: [MOAB-dev] Error message when compiling the mbcoupler_test.cpp
>> Hi all,
>> My name is Jie and I am part of computational mechanics group at civil
>> engineering dept. of Columbia university.
>> I am working on large deformation problems which may lead mesh distortions
>> and a re-meshing become necessary.
>> I would like to compile mbcoupler_test.cpp to learn how it transfer the
>> variables from old to the new mesh.
>> Now I can successfully compile the codes in build/examples and they works
>> good! But I cannot compile the codes in folder build/tools/mbcoupler by
>> following the instructions in build/tools/readme.tools, which shows error
>> message like following.
>> Do you have any idea for this problem? Thanks a lot!
>> Best,
>> Jie
>> DataCoupler.cpp:136:25: error: member access into incomplete
>>  type 'moab::ParallelComm'
>> if (myPcomm && myPcomm->size() > 1) {
>> ./DataCoupler.hpp:34:7: note: forward declaration of
>> class ParallelComm;
>> DataCoupler.cpp:161:12: error: member access into incomplete
>> myPcomm->proc_config().crystal_router()->gs_tran...
>> class ParallelComm;
>> DataCoupler.cpp:187:12: error: member access into incomplete
>> class ParallelComm;
>> 3 errors generated.
>> make[2]: *** [DataCoupler.lo] Error 1
>> make[2]: *** Waiting for unfinished jobs....
>> Coupler.cpp:344:45: error: no member named 'gs_transfer' in
>>  'moab::gs_data::crystal_data'
>> (myPc->proc_config().crystal_router())->gs_trans...
>> Coupler.cpp:388:45: error: no member named 'gs_transfer' in
>> Coupler.cpp:611:45: error: no member named 'gs_transfer' in
>> Coupler.cpp:638:43: error: no member named 'gs_transfer' in
>> myPc->proc_config().crystal_router()->gs_transfe...
>> 4 errors generated.
>> make[2]: *** [Coupler.lo] Error 1
>> make[1]: *** [all-recursive] Error 1
>> make: *** [all-recursive] Error 1
