[MOAB-dev] Building moab with cgm?
JR Cary cary at txcorp.com
Thu Dec 17 08:44:55 CST 2015
Hi Vijay,  Before I do that, just briefly, since you ask for config.log,
I'll mention that I am using CMake.  Should that work?
Thx...John
On 12/17/15 7:39 AM, Vijay S. Mahadevan wrote:
> John,
> All users should only be branching off from or directly using master
> branch and not develop branch. The "develop" branch is our throwaway
> integration branch which is under active development and so we make no
> guarantees of clean builds on all configuration combinations due to
> some untested features. The master branch should always be stable and
> shouldn't have any problems (hopefully). This philosophy is true
> across the stack (CGM/MOAB/MeshKit).
> I haven't seen those errors before. Perhaps the other devs can chime
> in. Can you also send along your MOAB config.log ?
> Vijay
> On Thu, Dec 17, 2015 at 4:05 AM, JR Cary <cary at txcorp.com> wrote:
>> I've just created a fresh branch of develop of CGM and configured
>> it with cmake, then built and installed it.
>> I also have a fresh branch of develop of MOAB.  I configure it
>> with cmake, then try to build it.  It fails at
>> /home/research/cary/projects/composerall/moab/src/io/ReadCGM.cpp: In member
>> function ‘moab::ErrorCode
>> moab::ReadCGM::store_surface_senses(std::map<RefEntity*, long unsigned
>> int>&, std::map<RefEntity*, long unsigned int>&)’:
>> /home/research/cary/projects/composerall/moab/src/io/ReadCGM.cpp:256:11:
>> error: ‘cout’ is not a member of ‘std’
>>             std::cout << "Surface " << face->id() << " has reverse sense " <<
>> I fixed those by including <iostream>, but then I get errors like
>> /home/research/cary/projects/composerall/moab/src/io/ReadCGM.cpp:689:11:
>> error: ‘ModelEntity’ was not declared in this scope
>>     DLIList<ModelEntity*> me_list;
>> At this point I see that there exists ModelEntity.hpp in the CGM source
>> but not in the installation.  I tried adding it to the installation, but
>> then CGM fails to compile.
>> Is this something that should be fixed in cgm?
>> Or am I doing something different from how you get moab to compile?
>> Thx.....John
