[MOAB-dev] Building moab with cgm?
    Vijay S. Mahadevan
    vijay.m at gmail.com
    Thu Dec 17 08:39:46 CST 2015
John,
All users should only be branching off from or directly using master
branch and not develop branch. The "develop" branch is our throwaway
integration branch which is under active development and so we make no
guarantees of clean builds on all configuration combinations due to
some untested features. The master branch should always be stable and
shouldn't have any problems (hopefully). This philosophy is true
across the stack (CGM/MOAB/MeshKit).
I haven't seen those errors before. Perhaps the other devs can chime
in. Can you also send along your MOAB config.log ?
Vijay
On Thu, Dec 17, 2015 at 4:05 AM, JR Cary <cary at txcorp.com> wrote:
> I've just created a fresh branch of develop of CGM and configured
> it with cmake, then built and installed it.
> I also have a fresh branch of develop of MOAB.  I configure it
> with cmake, then try to build it.  It fails at
> /home/research/cary/projects/composerall/moab/src/io/ReadCGM.cpp: In member
> function ‘moab::ErrorCode
> moab::ReadCGM::store_surface_senses(std::map<RefEntity*, long unsigned
> int>&, std::map<RefEntity*, long unsigned int>&)’:
> /home/research/cary/projects/composerall/moab/src/io/ReadCGM.cpp:256:11:
> error: ‘cout’ is not a member of ‘std’
>            std::cout << "Surface " << face->id() << " has reverse sense " <<
> I fixed those by including <iostream>, but then I get errors like
> /home/research/cary/projects/composerall/moab/src/io/ReadCGM.cpp:689:11:
> error: ‘ModelEntity’ was not declared in this scope
>    DLIList<ModelEntity*> me_list;
> At this point I see that there exists ModelEntity.hpp in the CGM source
> but not in the installation.  I tried adding it to the installation, but
> then CGM fails to compile.
> Is this something that should be fixed in cgm?
> Or am I doing something different from how you get moab to compile?
> Thx.....John
