[MOAB-dev] problem with pcomm
    jain at mcs.anl.gov
    jain at mcs.anl.gov
    Thu Dec  3 12:28:51 CST 2015
Do you have Fortran enabled? If so, how do you get gfortran? Also, do you use open-mpi or mpich?Does your make check pass?
Rajeev
  On Thu, 3 Dec, 2015 at 10:45, Lorenzo Alessio Botti<bottilorenzo at gmail.com> wrote:
636   Clang:*)
637     FATHOM_CXX_SPECIAL="$EXTRA_GNU_FLAGS -stdlib=libc++"
638     FATHOM_CXX_32BIT=-m32
639     FATHOM_CXX_64BIT=-m64
640     ;;
641   SunWorkshop:i?86|SunWorkshop:x86_64)
642     FATHOM_CXX_32BIT=-m32
643     FATHOM_CXX_64BIT=-m64
644     ;;
645   *)
646     ;;
647 esac
648 AC_MSG_RESULT([$cxx_compiler:$host_os:$host_cpu])
649
650 # Check for specific overrides
651 CXX_LDFLAGS=""
652 if (test "$cxx_compiler:${host_os:0:6}" == "Clang:darwin"); then
653   CXX_LDFLAGS="$CXX_LDFLAGS -stdlib=libc++"
654   LIBS="$LIBS -lc++”
I changed lines 637 and 653 of compilers.m4 as you suggested (libc++ instead of libstdc++).My code runs fine (I’m on Mavericks with latests clang). As opposite to the previous build make check now get suck at dual_test. The other tests runs fine.
Thanks everybody for help! As Vijay pointed out I thinks this is the way to go since it allows to use c++11.
Thanks again.Bests.Lorenzo
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20151203/5cf3f4c5/attachment.html>
