[MOAB-dev] problem with pcomm
    Lorenzo Alessio Botti
    bottilorenzo at gmail.com
    Thu Dec  3 10:05:38 CST 2015
Yes, lorbot.
Thanks. I’ll check it out.
Lorenzo
> On 03 Dec 2015, at 16:45, Lorenzo Alessio Botti <bottilorenzo at gmail.com> wrote:
>> 636   Clang:*)
>> 637     FATHOM_CXX_SPECIAL="$EXTRA_GNU_FLAGS -stdlib=libc++"
>> 638     FATHOM_CXX_32BIT=-m32
>> 639     FATHOM_CXX_64BIT=-m64
>> 640     ;;
>> 641   SunWorkshop:i?86|SunWorkshop:x86_64)
>> 642     FATHOM_CXX_32BIT=-m32
>> 643     FATHOM_CXX_64BIT=-m64
>> 644     ;;
>> 645   *)
>> 646     ;;
>> 647 esac
>> 648 AC_MSG_RESULT([$cxx_compiler:$host_os:$host_cpu])
>> 649
>> 650 # Check for specific overrides
>> 651 CXX_LDFLAGS=""
>> 652 if (test "$cxx_compiler:${host_os:0:6}" == "Clang:darwin"); then
>> 653   CXX_LDFLAGS="$CXX_LDFLAGS -stdlib=libc++"
>> 654   LIBS="$LIBS -lc++”
> I changed lines 637 and 653 of compilers.m4 as you suggested (libc++ instead of libstdc++).
> My code runs fine (I’m on Mavericks with latests clang).
> As opposite to the previous build make check now get suck at dual_test.
> The other tests runs fine.
> Thanks everybody for help!
> As Vijay pointed out I thinks this is the way to go since it allows to use c++11.
> Thanks again.
> Bests.
> Lorenzo
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20151203/612d51de/attachment.html>
