[MOAB-dev] problem with pcomm
Vijay S. Mahadevan
vijay.m at gmail.com
Thu Dec 3 12:34:31 CST 2015
Rajeev, Lorenzo's configuration does not have fortran enabled. He uses
mpich3 and yes make check passes, except for dual_test when he
comments out the CXX_LDFLAGS change.
I'm checking this right now. I get some undefined errors for "operator
<<" when I don't include -lstdc++ on Mavericks. So clearly, removing
it directly is not a fix. Perhaps we need to check the Darwin Kernel
version and configure accordingly.
Vijay
On Thu, Dec 3, 2015 at 1:28 PM, jain at mcs.anl.gov <jain at mcs.anl.gov> wrote:
> Do you have Fortran enabled? If so, how do you get gfortran? Also, do you
> use open-mpi or mpich?
> Does your make check pass?
> Rajeev
> On Thu, 3 Dec, 2015 at 10:45, Lorenzo Alessio Botti
> <bottilorenzo at gmail.com> wrote:
> 636 Clang:*)
> 637 FATHOM_CXX_SPECIAL="$EXTRA_GNU_FLAGS -stdlib=libc++"
> 638 FATHOM_CXX_32BIT=-m32
> 639 FATHOM_CXX_64BIT=-m64
> 640 ;;
> 641 SunWorkshop:i?86|SunWorkshop:x86_64)
> 642 FATHOM_CXX_32BIT=-m32
> 643 FATHOM_CXX_64BIT=-m64
> 644 ;;
> 645 *)
> 646 ;;
> 647 esac
> 648 AC_MSG_RESULT([$cxx_compiler:$host_os:$host_cpu])
> 649
> 650 # Check for specific overrides
> 651 CXX_LDFLAGS=""
> 652 if (test "$cxx_compiler:${host_os:0:6}" == "Clang:darwin"); then
> 653 CXX_LDFLAGS="$CXX_LDFLAGS -stdlib=libc++"
> 654 LIBS="$LIBS -lc++”
> I changed lines 637 and 653 of compilers.m4 as you suggested (libc++ instead
> of libstdc++).
> My code runs fine (I’m on Mavericks with latests clang).
> As opposite to the previous build make check now get suck at dual_test.
> The other tests runs fine.
> Thanks everybody for help!
> As Vijay pointed out I thinks this is the way to go since it allows to use
> c++11.
> Thanks again.
> Bests.
> Lorenzo
