[MOAB-dev] [Nek5000-users] MOAB partitioning
Vijay S. Mahadevan
vijay.m at gmail.com
Thu Nov 5 11:48:42 CST 2015
Emilian, I don't see what is the problem anymore. MOAB successfully
configured according to your logs and mbpart will be built with Metis
support. From your output:
METIS_INC_FLAGS='-I/home/owp/METIS/metis-5.1.0/include'
METIS_LIBS='-L/home/owp/METIS/metis-5.1.0 -lmetis'
#define HAVE_METIS 1
So I don't see any issues here. Send us the error output from make ?
Vijay
On Thu, Nov 5, 2015 at 11:39 AM, Popov, Emilian L. <popove at ornl.gov> wrote:
> Hello Vijay,
> Is there any resolution on the below.
> Thanks,
> -emilian
> From: nek5000-users-bounces at lists.mcs.anl.gov
> [mailto:nek5000-users-bounces at lists.mcs.anl.gov] On Behalf Of
> nek5000-users at lists.mcs.anl.gov
> Sent: Tuesday, October 27, 2015 2:59 PM
> To: nek5000-users at lists.mcs.anl.gov; moab-dev at mcs.anl.gov
> Subject: Re: [Nek5000-users] MOAB partitioning
> Emilian,
> Let's fix the MOAB related issues first on the MOAB mailing list. Please
> send us your config.log file so that we can provide pointers to fix the
> configuration problems. Once this is done, we can revisit NEK-MOAB.
> Vijay
> On Monday, October 26, 2015, <nek5000-users at lists.mcs.anl.gov> wrote:
> Vijay,
> I downloaded moab-4.8.2 and configured and then ran ‘make’, but am getting
> errors from missing ‘mpi.h’ and metis.h, perhaps the configuration is not
> OK?
> Thanks,
> -emilian
> Sent: Friday, October 23, 2015 12:24 PM
> What version of MOAB are you using ? It should be available with the last
> MOAB 4.8.2 release [1] I think. Let us know if you have problems.
> Vijay
> [1] http://ftp.mcs.anl.gov/pub/fathom/moab-4.8.2.tar.gz
> On Friday, October 23, 2015, <nek5000-users at lists.mcs.anl.gov> wrote:
> Thanks Vijay, however the option ‘—with-metis’ does not seem to exist,
> please advice.
> -emilian
> Sent: Friday, October 23, 2015 11:35 AM
> Emilian,
> If you want the partitioner tools, you need to configure MOAB with either
> metis (--with-metis=DIR) or with zoltan and optionally parmetis. Let us know
> if you have questions. The metis installation route is extremely
> straightforward and you should not encounter any issues.
> Vijay
> Dear Nek/Moab users,
> I built Moab, but in the bin folder the ‘mbpart’ code is missing and I need
> it to partition an .h5m mesh file for Nek.
> Any suggestions?
> Thanks,
> -emilian
