[MOAB-dev] OCC STP file loading and senses interpretation
jain at mcs.anl.gov jain at mcs.anl.gov
Fri Aug 28 14:43:31 CDT 2015
See the message below from Evan. Does anyone have concerns about this change?CGM change: https://bitbucket.org/fathomteam/cgm/branch/vanderzee/faceVolSense
caused MOAB change:  https://bitbucket.org/fathomteam/moab/branch/vanderzee/faceVolSense
      On Friday, August 28, 2015 2:21 PM, "Vander Zee, Evan B." <vanderzee at anl.gov> wrote:
 #yiv8444884465 #yiv8444884465 -- _filtered #yiv8444884465 {font-family:Helvetica;panose-1:2 11 6 4 2 2 2 2 2 4;} _filtered #yiv8444884465 {font-family:Helvetica;panose-1:2 11 6 4 2 2 2 2 2 4;} _filtered #yiv8444884465 {font-family:Calibri;panose-1:2 15 5 2 2 2 4 3 2 4;} _filtered #yiv8444884465 {font-family:Tahoma;panose-1:2 11 6 4 3 5 4 4 2 4;} _filtered #yiv8444884465 {font-family:Verdana;panose-1:2 11 6 4 3 5 4 4 2 4;}#yiv8444884465 #yiv8444884465 p.yiv8444884465MsoNormal, #yiv8444884465 li.yiv8444884465MsoNormal, #yiv8444884465 div.yiv8444884465MsoNormal {margin:0in;margin-bottom:.0001pt;font-size:12.0pt;}#yiv8444884465 a:link, #yiv8444884465 span.yiv8444884465MsoHyperlink {color:blue;text-decoration:underline;}#yiv8444884465 a:visited, #yiv8444884465 span.yiv8444884465MsoHyperlinkFollowed {color:purple;text-decoration:underline;}#yiv8444884465 p {margin-right:0in;margin-left:0in;font-size:12.0pt;}#yiv8444884465 p.yiv8444884465MsoAcetate, #yiv8444884465 li.yiv8444884465MsoAcetate, #yiv8444884465 div.yiv8444884465MsoAcetate {margin:0in;margin-bottom:.0001pt;font-size:8.0pt;}#yiv8444884465 p.yiv8444884465msoacetate, #yiv8444884465 li.yiv8444884465msoacetate, #yiv8444884465 div.yiv8444884465msoacetate {margin-right:0in;margin-left:0in;font-size:12.0pt;}#yiv8444884465 p.yiv8444884465msonormal, #yiv8444884465 li.yiv8444884465msonormal, #yiv8444884465 div.yiv8444884465msonormal {margin-right:0in;margin-left:0in;font-size:12.0pt;}#yiv8444884465 p.yiv8444884465msochpdefault, #yiv8444884465 li.yiv8444884465msochpdefault, #yiv8444884465 div.yiv8444884465msochpdefault {margin-right:0in;margin-left:0in;font-size:12.0pt;}#yiv8444884465 p.yiv8444884465msonormal1, #yiv8444884465 li.yiv8444884465msonormal1, #yiv8444884465 div.yiv8444884465msonormal1 {margin-right:0in;margin-left:0in;font-size:12.0pt;}#yiv8444884465 p.yiv8444884465msoacetate1, #yiv8444884465 li.yiv8444884465msoacetate1, #yiv8444884465 div.yiv8444884465msoacetate1 {margin-right:0in;margin-left:0in;font-size:12.0pt;}#yiv8444884465 p.yiv8444884465msochpdefault1, #yiv8444884465 li.yiv8444884465msochpdefault1, #yiv8444884465 div.yiv8444884465msochpdefault1 {margin-right:0in;margin-left:0in;font-size:12.0pt;}#yiv8444884465 span.yiv8444884465msohyperlink {}#yiv8444884465 span.yiv8444884465msohyperlinkfollowed {}#yiv8444884465 span.yiv8444884465balloontextchar {}#yiv8444884465 span.yiv8444884465msohyperlink1 {}#yiv8444884465 span.yiv8444884465msohyperlinkfollowed1 {}#yiv8444884465 span.yiv8444884465emailstyle181 {}#yiv8444884465 span.yiv8444884465balloontextchar1 {}#yiv8444884465 span.yiv8444884465emailstyle34 {}#yiv8444884465 span.yiv8444884465emailstyle35 {}#yiv8444884465 p.yiv8444884465msonormal2, #yiv8444884465 li.yiv8444884465msonormal2, #yiv8444884465 div.yiv8444884465msonormal2 {margin:0in;margin-bottom:.0001pt;font-size:12.0pt;}#yiv8444884465 span.yiv8444884465msohyperlink2 {color:blue;text-decoration:underline;}#yiv8444884465 span.yiv8444884465msohyperlinkfollowed2 {color:purple;text-decoration:underline;}#yiv8444884465 p.yiv8444884465msoacetate2, #yiv8444884465 li.yiv8444884465msoacetate2, #yiv8444884465 div.yiv8444884465msoacetate2 {margin:0in;margin-bottom:.0001pt;font-size:12.0pt;}#yiv8444884465 span.yiv8444884465balloontextchar2 {}#yiv8444884465 p.yiv8444884465msonormal3, #yiv8444884465 li.yiv8444884465msonormal3, #yiv8444884465 div.yiv8444884465msonormal3 {margin-right:0in;margin-left:0in;font-size:12.0pt;}#yiv8444884465 p.yiv8444884465msochpdefault2, #yiv8444884465 li.yiv8444884465msochpdefault2, #yiv8444884465 div.yiv8444884465msochpdefault2 {margin-right:0in;margin-left:0in;font-size:12.0pt;}#yiv8444884465 p.yiv8444884465msonormal11, #yiv8444884465 li.yiv8444884465msonormal11, #yiv8444884465 div.yiv8444884465msonormal11 {margin:0in;margin-bottom:.0001pt;font-size:12.0pt;}#yiv8444884465 p.yiv8444884465msoacetate11, #yiv8444884465 li.yiv8444884465msoacetate11, #yiv8444884465 div.yiv8444884465msoacetate11 {margin:0in;margin-bottom:.0001pt;font-size:8.0pt;}#yiv8444884465 p.yiv8444884465msochpdefault11, #yiv8444884465 li.yiv8444884465msochpdefault11, #yiv8444884465 div.yiv8444884465msochpdefault11 {margin:0in;margin-bottom:.0001pt;font-size:10.0pt;}#yiv8444884465 span.yiv8444884465msohyperlink11 {color:blue;text-decoration:underline;}#yiv8444884465 span.yiv8444884465msohyperlinkfollowed11 {color:purple;text-decoration:underline;}#yiv8444884465 span.yiv8444884465emailstyle1811 {color:#1F497D;}#yiv8444884465 span.yiv8444884465balloontextchar11 {}#yiv8444884465 span.yiv8444884465emailstyle341 {color:#1F497D;}#yiv8444884465 span.yiv8444884465emailstyle351 {color:#1F497D;}#yiv8444884465 span.yiv8444884465EmailStyle49 {color:#1F497D;}#yiv8444884465 span.yiv8444884465BalloonTextChar {}#yiv8444884465 .yiv8444884465MsoChpDefault {font-size:10.0pt;} _filtered #yiv8444884465 {margin:1.0in 1.0in 1.0in 1.0in;}#yiv8444884465 div.yiv8444884465WordSection1 {}#yiv8444884465 In review of the pull request I created, it came up that the read_cgm_senses_test of MOAB was broken by this change.  I have pushed an updated version of that test to a vanderzee/faceVolSense branch of the MOAB repository.  With that change, my local build of moab-oce passes all of the tests in make check.    This particular test has hard-coded what face-to-volume and edge-to-face senses it expects to get when it reads MeshFiles/unittest/io/cylcube.stp file.  The geometry contains two volumes, a cube and a cylinder, that do not touch or overlap.  Since my changes to CGM now produce normal vectors and face-to-volume senses that are in accordance with what is stored in the .stp file rather than always producing a forward sense on all faces and not having the sense in accordance with the normal vector, and since some of the faces in the .stp file have reversed sense, the face-to-volume and edge-to-face senses that this test expects needed to be changed.    In the attached spreadsheet – which I think will open in OpenOffice if you don’t have Excel – I describe the changes I’ve made in a way that’s probably a bit easier to understand than the code. I have an initial table that shows how all 10 faces expected a forward (F) sense, but now half of them expect a reverse (R) sense. In the lower table I list the edge-to-face senses. Here the expectation is that wherever the sense of a face has changed to the reverse sense, the sense of the edge with respect to that face should flip.  You should be able to see how my changes respect that.  Also, the order in which the edges are read changed slightly, so edges 6 and 8 swapped IDs.    I also made some changes to the check_sense_data method of the test so that the test does not depend on having the known senses and the senses read from the file in the same order. This seemed to be the intent of that method, but was not behaving that way. If the test is supposed to depend on reading things in the same order, you can revert the two lines I added to that method, and the test will still pass. Finally, I changed the test to check the face-to-volume senses before it checks the edge-to-face senses, because the expectation one has for edge-to-face sense depends on the face-to-volume sense. That reflects a preference that I have, but again, is not at all essential.    -Evan
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20150828/0a55d661/attachment.html>
Type: application/vnd.openxmlformats-officedocument.spreadsheetml.sheet
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20150828/0a55d661/attachment.xlsx>
