[MOAB-dev] [Lasso-dev] make check fail
    jain at mcs.anl.gov
    jain at mcs.anl.gov
    Wed Aug 26 17:05:20 CDT 2015
Take that back. You need mbconvert only for formats with special build options. Exodus format is available from the GUI itself. If you just specify the mesh file name with appropriate extension in the "Configure" tab of the core view in the RGG GUI. There is a field "Output Mesh File", specify "mesh.exo" and it should write "mesh.exo" as an exodus file. You can specify vtk and other format that MOAB supports. Thanks Tim for pointing out.
Rajeev Jain
Software Development Specialist
MCS, Argonne National Laboratory
1147, Bldg 240, O: 630-252-3176
Gmail: rajeeja GVoice 312-RAJ-EEV0
jain at anl.gov
     On Wednesday, August 26, 2015 4:18 PM, "Jain, Rajeev" <jain at mcs.anl.gov> wrote:
  Hi Vishal,
You need MOAB's mbconvert utility for converting h5m file to exodus. Details on building MOAB are here: http://sigma.mcs.anl.gov/moab/building-moab/We (SIGMA) team supports various other formats, see SIGMA page for details.
I'll pass your message about "Apply" button to the Kitware team. Please send other such feature requests of problems you encounter with RGG to MeshKit-Dev list.
Also, please share pictures of models you generate - if your work is okay with sharing the model you generate.Thanks.
_________________________________________
Rajeev Jain
Mathematics and Computer Science Division
Rm 1147, Bldg 240
9700 South Cass Avenue
Argonne, IL 60439-4844
630-252-3176
630-252-5986 (fax)
jain at mcs.anl.gov
On Wed, Aug 26, 2015 at 11:22 AM, Vishal Patel <vpatel314 at gmail.com> wrote:
Hello again,Is there a place to ask questions or is email okay? I wanted to know if different mesh formats than h5m were supported such as exodus? I tried changing the output file name to be .e, mesh generates but I can't visualize it in cubit or paraview so I assume something went wrong. I used the example model 12th core input.
Also, as for a GUI suggestion, I've forgotten to hit apply pretty much after every change I've made. A warning that changes were made w/o apply when switching to a different part of the software would be great. Otherwise, I had no trouble making an NTR fuel element and tietube.
Vishal Patel
Graduate Researcher / Next Degree Student
Nuclear Engineering
Texas A&M University / Center for Space Nuclear Research
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20150826/6db45600/attachment.html>
