[MOAB-dev] Does Moab Coupler only work on 3D meshes?
魏华祎 huayiwei1984 at gmail.com
Wed Jul 8 20:56:08 CDT 2015
My application mesh is a block structured mesh, which vertices will
move and hence the mesh quality will become bad,  so I need to
optimize the location of mesh vertices. Then I need to tansfer data
from old mesh to new mesh. That's my problem.  My program is parallel
and there is a structured quad mesh on each processor.  By the way,
my program is not based on Moab. But I want to use
the coupler tool in moab. So fristly I need transfer my mesh into Moab.
At present, I explicityly transfer my every block mesh to the
repesentation of vertices and coonecicity, just as your suggection. I
am writing a test first. Dose you have better idea about it?
2015-07-09 9:36 GMT+08:00 Vijay S. Mahadevan <vijay.m at gmail.com>:
> If you are asking about the ScdBox structure, I'm unsure. I don't
> think we have a test for this. However, if you explicitly represent
> the vertices and connectivity, usage of a structured grid is
> transparent to MOAB interfaces and everything should work as is.
> What type of problems are you solving ? Are you using a logically
> structured or performing stencil computations ?
> Vijay
> On Wed, Jul 8, 2015 at 8:33 PM, 魏华祎 <huayiwei1984 at gmail.com> wrote:
>> Hi, Vijay,
>> Thanks for your reply.  So it also work on Structured Mesh
>> Representation of Moab?
>> Best
>> Huayi
>> 2015-07-09 6:50 GMT+08:00 Vijay S. Mahadevan <vijay.m at gmail.com>:
>>> No it should work for any dimension and is not restricted to 3-D. Have
>>> you tried using the coupler for your problem ? If you have issues,
>>> send us a test case and the meshes. You can also use mbcoupler_test to
>>> verify whether the solution defined on your source mesh is being
>>> transferred correctly onto the target mesh.
>>> Vijay
>>> On Wed, Jul 8, 2015 at 5:33 PM, 魏华祎 <huayiwei1984 at gmail.com> wrote:
>>>> Hi, There,
>>>> I am trying to use Moab Coupler transfer data between 2d meshes, but I
>>>> am not sure if  it works on 2d mesh.
>>>> Please give me some suggestion, thanks very much.
>>>> Best
>>>> Huayi
