[MOAB-dev] coupler test can not work well
魏华祎 huayiwei1984 at gmail.com
Thu Jul 9 08:44:35 CDT 2015
Hi, MOAB Developer,
I  code a very simple test , please see the attachment.  The source
mesh is  following:
(-1, 1) ------------(0, 1)--------------(1, 1)
(-1, 0)-------------(0, 0)-------------(1, 0)
(-1, -1)------------(0, -1)------------(1, -1)
In every quad, there is a constant. For example, [1.0, 2.0, 2.0, 3.0]
( from left to right and bottom to up) .
I just change point (0, 0)  as (0.3, 0.4) to get the target mesh.
I can compile it, but when I run it, it throw a segment error.
This is my first time to use mb coupler tool, and not sure what
mistake I have made, so I need your help.
Thanks very much.
Best
Huayi
2015-07-09 9:56 GMT+08:00 魏华祎 <huayiwei1984 at gmail.com>:
> My application mesh is a block structured mesh, which vertices will
> move and hence the mesh quality will become bad,  so I need to
> optimize the location of mesh vertices. Then I need to tansfer data
> from old mesh to new mesh. That's my problem.  My program is parallel
> and there is a structured quad mesh on each processor.  By the way,
> my program is not based on Moab. But I want to use
> the coupler tool in moab. So fristly I need transfer my mesh into Moab.
> At present, I explicityly transfer my every block mesh to the
> repesentation of vertices and coonecicity, just as your suggection. I
> am writing a test first. Dose you have better idea about it?
> 2015-07-09 9:36 GMT+08:00 Vijay S. Mahadevan <vijay.m at gmail.com>:
>> If you are asking about the ScdBox structure, I'm unsure. I don't
>> think we have a test for this. However, if you explicitly represent
>> the vertices and connectivity, usage of a structured grid is
>> transparent to MOAB interfaces and everything should work as is.
>> What type of problems are you solving ? Are you using a logically
>> structured or performing stencil computations ?
>> Vijay
>> On Wed, Jul 8, 2015 at 8:33 PM, 魏华祎 <huayiwei1984 at gmail.com> wrote:
>>> Hi, Vijay,
>>> Thanks for your reply.  So it also work on Structured Mesh
>>> Representation of Moab?
>>> Best
>>> Huayi
>>> 2015-07-09 6:50 GMT+08:00 Vijay S. Mahadevan <vijay.m at gmail.com>:
>>>> No it should work for any dimension and is not restricted to 3-D. Have
>>>> you tried using the coupler for your problem ? If you have issues,
>>>> send us a test case and the meshes. You can also use mbcoupler_test to
>>>> verify whether the solution defined on your source mesh is being
>>>> transferred correctly onto the target mesh.
>>>> Vijay
>>>> On Wed, Jul 8, 2015 at 5:33 PM, 魏华祎 <huayiwei1984 at gmail.com> wrote:
>>>>> Hi, There,
>>>>> I am trying to use Moab Coupler transfer data between 2d meshes, but I
>>>>> am not sure if  it works on 2d mesh.
>>>>> Please give me some suggestion, thanks very much.
>>>>> Best
>>>>> Huayi
Type: text/x-c++src
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20150709/b1873f5e/attachment.cpp>
