[MOAB-dev] Does Moab Coupler only work on 3D meshes?
Vijay S. Mahadevan vijay.m at gmail.com
Wed Jul 8 20:36:27 CDT 2015
If you are asking about the ScdBox structure, I'm unsure. I don't
think we have a test for this. However, if you explicitly represent
the vertices and connectivity, usage of a structured grid is
transparent to MOAB interfaces and everything should work as is.
What type of problems are you solving ? Are you using a logically
structured or performing stencil computations ?
Vijay
On Wed, Jul 8, 2015 at 8:33 PM, 魏华祎 <huayiwei1984 at gmail.com> wrote:
> Hi, Vijay,
> Thanks for your reply.  So it also work on Structured Mesh
> Representation of Moab?
> Best
> Huayi
> 2015-07-09 6:50 GMT+08:00 Vijay S. Mahadevan <vijay.m at gmail.com>:
>> No it should work for any dimension and is not restricted to 3-D. Have
>> you tried using the coupler for your problem ? If you have issues,
>> send us a test case and the meshes. You can also use mbcoupler_test to
>> verify whether the solution defined on your source mesh is being
>> transferred correctly onto the target mesh.
>> Vijay
>> On Wed, Jul 8, 2015 at 5:33 PM, 魏华祎 <huayiwei1984 at gmail.com> wrote:
>>> Hi, There,
>>> I am trying to use Moab Coupler transfer data between 2d meshes, but I
>>> am not sure if  it works on 2d mesh.
>>> Please give me some suggestion, thanks very much.
>>> Best
>>> Huayi
